Skystar 2 Error Code
Old 04-05-2008   #1
My System: Skystar 2 PCI card 1 mtr Dish
Hello all, i'm new to all this so please bare with me.
I have a Skystar 2 PCI card installed in my home pc, I fitted it about a year ago and ive had a play with it on and off and used different drivers and finally got it working, but I think ive upset the card by unplugging the cable to my dish and then plugging in one of them satellite finder buzzer pieces of kit while my computer was still switched on, yes I know I should of switched it off but i'm the impatient type, haha.
So now I go into my device manager and it tells me I have an error this device cannot start. (Code 10).
B2C2 Broadband Receiver PCI Adaptor
The driver date is 03/05/2004,
the driver version is 4.2.11.9999
Now i've disabled and enabled the device in device manager and deleted the device and re-installed it but it still says I have a code 10 error.
So my new friends I thought i'd ask the experts on what I can do to get my free channels again.
Thanks for your time in reading my first newbie post......
Dr Fettish is offline   Reply With Quote
Old 04-05-2008   #2
Archived Member
The big question is if the card was damaged.
Can you try installing it in another PC and see if you can get it to work, provided this PC has the minimum system requirements.
If no other PC is available, take out the card physically, uninstall all the drivers, reboot and then install it again and just follow the instructions as if this is a new card and hopefully you will get it to work.
While the card is out, inspect it for any visible damage. Beware of ESD.
Good Luck.
HB13DISH is offline   Reply With Quote
The Following User Says Thank You to HB13DISH For This Useful Post:
Dr Fettish (05-05-2008)
Old 04-05-2008   #3
Amo Amas Amant Admin
Topper's Avatar
Also
Good Luck.
Just in case Dr Fettish does not know, ESD stands for electrostatic discharge. This should involve the use of an earthed wristband, however if you do not have one to hand and as you are (self confessed) impatient ensure the PC is switched off and unplugged then touch one of the screws holding on the plug socket before touching the card, to ensure any static build up in your body is discharged. Sometime a crack can be heard as the charge in your body leaks to earth and be warned is can under certain conditions hurt a little bit.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
Old 05-05-2008   #4
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Given the username that might not be a problem
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 05-05-2008   #5
Topper's Avatar
Mmmm
Lol you could very well be spot on there
Show Your Support
Thank you.
Old 05-05-2008   #6
I must admit I had to think for a second what ESD was but being a sparky I soon worked it out and I have a wristband that Topper is on about as my father used to work at BT and he had about 4 of em.
Thanks for the advice guys i'll give it a go in the wifes PC and see what happens, i'll let you all know later.....
Old 05-05-2008   #7
Oh yeah but electricity does hurt cause ive had a few good shocks in my time and i'm not talking about when the wife told me she was preggers, hahhahahaha......
Old 05-05-2008   #8
Topper's Avatar
Ermm
No more details please
Show Your Support
Thank you.
code, error, skystar
