Nova-HD-S2
Old 25-05-2008   #1
My System: Nova S2 Card Fixed Dish @ 28E
Nova-HD-S2
I have a nova hd s2 which is currently connected to a minidish and i am getting the freesat channels
i am thinking of getting a new dish with a diseqc motor to put up as well
i would like to know if anyone has got this card working with controlling a disecq motor as officially it only supports 1.0, on the hauppauge support forum they say that if you try this it could blow the board, the lnb or both and i don't want to do that.
i was thinking that if the board couldn't supply enough power for the motor and the lnb at the same time then would it be possible to use a 4 way diseqc switch, have one connected to just the motor, one connected to the new lnb and then one connected to the current lnb on the minidish
i've done a lot of searching and can't seem to find an answer so any help would be appreciated
Thanks.
Phil.
nexuss is offline   Reply With Quote
Old 10-06-2008   #2
My System: win xp sky star 2
I thenk To use Muator poisioner is needed to take electricity from a separate source
rageb is offline   Reply With Quote
novahds2
