SkyStar HD2 installation problemDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 08-06-2008 Location: Kuwait
My System: AMD 4400+ X2 2GB Ram Windows Vista Geforce 7900 GS SkyStar HD2 SkyStar CI-Slot HD 2 |
Hi I've just purchased SkyStar HD2, and everytime i install it it goes under "Sound, video and game controllers" I've read somewhere else that it should be under "Network adapters" so there is might be a problem with the installation. And everytime i run ProgDVB5 i get this message "Device not started! (skystar 2). Please help me | ||
| Member Join Date: 22-07-2003
Hi DigiQ8 I've got skystar HD and I have just checked that there are no network drivers in Device manager for skystar HD I think you only need those network drivers if you use progdvb I'm using Technisat TV centre which is good but best program is DVBViewer, I have subscibed to them I think it was 9 euros but a lot better prog than progdvb and of course you buy into an ongoing development I bought cam module and use dragon cam to clear HD progs on Premiere and other networks on 19 degs You can still clear them using Technisat TV centre of course what is skystar HD2 like any more advanced ? Mpopeye45 | ||
| Member Join Date: 04-01-2008 Location: India
My System: 6 Feet C band in Insat 2E 8 Feet C band in Asiasat 75 cm Ku in Insat 4B Kaon Receiver Pentium 4 1.7 GHz | I have SS2. It is listed as a network Adapator on device manager. It will be listed as Audio Video device, if you install the BDA driver. You need to set the device on progDVB -> settings -> Device list. Try BDA. You may got picture on ProgDVB. | ||
| | #5 | ||
My System: 6 Feet C band in Insat 2E 8 Feet C band in Asiasat 75 cm Ku in Insat 4B Kaon Receiver Pentium 4 1.7 GHz | For me, BDA driver is available on the CD. In your case, I have no idea. Serach the cd for it or download from technisat's site. I have no confirmation that BDA driver is vailable for your HD card. Visit the site for more info. Because of restriction, I am not ready to post the site address. I hope you know the address. It on the cover. | ||
| | #6 | ||
with skystar HD I downloaded T*chniSat TV Center 1.0.7.2 from their site BDA drivers in with installation right click on *.inf file and click on install then run setup when it asks for driver it should go to your setup directory I find its best to make your own folder for setup otherwise it disappears into Mydocuments/temp file hope you are able to follow this Is skystar HD2 the USB version ??? Mpopeye45 | ||
| | #7 | ||
I reformatted my computer and installed XP now it's working tho there is still a problem, it seems i can't view pay tv channels. I've inserted the cam and the progdvb can recognize it. but it just wont show the channel. Is there anything wrong i'm doing? btw the smart card is 100% working. Thanks for your replies . | ||
| | #10 | ||
My System: 6 Feet C band in Insat 2E 8 Feet C band in Asiasat 75 cm Ku in Insat 4B Kaon Receiver Pentium 4 1.7 GHz | Also, if the card is a paired one then you can't get picture on the DVB card. Try to find if the card is paired or not. | ||
| | #11 | ||
My System: AMD 4400+ X2 2GB Ram Windows Vista Geforce 7900 GS SkyStar HD2 SkyStar CI-Slot HD 2 | It's working great now, Thanks ![]() Tho i'm having problems with the HD Codec. I tried Elecard video decoder it's kinda good but have this noise look on it. What codec do you guys recommend (for H264 Channels). | ||
| | #12 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | CoreAVC should do the job nicely - _www.coreavc.com/ | ||
| The Following User Says Thank You to Llew For This Useful Post: | DigiQ8 (11-06-2008) |
| hd2, installation, problem, skystar |
