question on satellite pc card
Old 13-06-2008   #1
My System: hi
The signal level decrease to about 50% in satellite pc card comparing with any ordenary satellite receiver, is there any way to overcome this problem
thanks for help
zero2004 is offline   Reply With Quote
Old 13-06-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
I shouldn't rely too much on the readings displayed in your PC card application(s). I regularly get conflicting signal strength/quality readings for a given TP switching from, say, progDVB to DVB Dream, irrespective of the ability of the tuner to successfully scan its channels using the different applications.
Llew is online now   Reply With Quote
Old 13-06-2008   #3
My System: hi
i used many of pc card softwares and the results are same, the sensitive of received signal of normal receiver is better than pc card, please tell me if there is a way to increase received signal level.
thanks again
Old 13-06-2008   #4
Llew's Avatar
No point if you are already getting a good signal level with your STB.
Are you just swapping the same cable from your STB to your PC card?
More to the point, with your PC card, is the signal quality dropping low enough for you to lose channels that you receive OK with your STB?
If that's the case, I would suspect a poor PC card tuner.
Old 14-06-2008   #5
My System: hi
Dear LIew
i used a twin LNB, one cable connect to stb and the other to pc card(skystar2), some channels losed in pc but i can see it on stb
thanks
Old 14-06-2008   #6
Llew's Avatar
May be the cable to your PC card. If you haven't already tried, can you swap the receiver / Skystar over and check signals that way?
card, question, satellite
