SS2 PRogDVB & Matrix CAM
Old 26-06-2008   #1
Lucifer's Avatar
My System: Phoenix Apollo ci converted to OpenBox. Sky_star 2 PCI card. Nokia DBox2c. Sagem Dbox2c. 60cm Channel Master @ 28° ALPS LNB. 60cm Channel Master @ 19° Syntec 2000LNB. Diseq Switch. Panasonic TU-DSB30. Duolabs Dynamite & Cas2+ interface. Matri
Hi all, Just got my self an old matrix cam (revolutions) and cas interface 2+ to play with off fleabay. Question is how do I get ProgDVB to see the cam, is it via the cas interface or do I need a pci to pcmcia adapter? I'm not that bothered about clearing much, its just for self education. I have in the past succesfully used my Sly card in ProgDVB & SS2 using NDSCam & Duolabs Dynamite in phoenix mode, so I figured I'd just need cam and cas interface to connect to ProgDVB but maybe I'm wrong! If I do need adapter from PCI to pcmcia is there a prefered one? Any help much appreciated.
Lucifer is offline   Reply With Quote
Old 26-06-2008   #2
Archived Member
I don't think that there is an adapter for SS2.
Try to open channels with plugins instead of CAM.
HB13DISH is offline   Reply With Quote
cam, matrix, progdvb, ss2
