Progdvb , CoreAVC & HD
Old 05-07-2008   #1
My System: HTPC
Is it possible to watch BBCHD channel with the free Standard version of Progdvb.
I have already paid for coreavc, so do I now have to puchase the pro version of Progdvb too?
Or is there a recommended free alternative software that will make use of coreavc to be able to watch the Hd stuff?
I have a Skystar2 card btw.
Cheers
Zen1 is offline   Reply With Quote
Old 05-07-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
DVBDream with CoreAVC will do it - and it's free, unlike ProgDVB Pro.
Skystar 2 will be OK, but you need a meaty processor. Mine works OK with a 2.8GHz Pentium though.
Llew is offline   Reply With Quote
Old 05-07-2008   #3
My System: HTPC
Well I persisted with Progdvb (elecard edition) and a downloaded filtergraph called avc.OVRL_CoreAVC_AC3.xgr.
I also needed xecore.ax to stop progdvb complaining.
My AMD 4600+ X2 seems to be ok at around 80% usage but occasionally picture stutters.
Is 1gig of ram to little ???
Old 05-07-2008   #4
Llew's Avatar
I recently changed up to 2gig, but I seem to remember it was OK before with 1.
Processor running at 58%, no probs with pic.
Old 06-07-2008   #5
My System: HTPC
Not sure I'll bother with more ram then yet.
Really struggling to get bbc hd in 16:9 format. The picture appears to be 4:3 in progdvb.
Anyone know how to fix this ?
Old 08-07-2008   #6
My System: HTPC
Now trying to get dvbdream to work with coreavc.
On bbchd it freezes but is ok in progdvb
Any ideas what the problem in dvbdream could be?
Old 08-07-2008   #7
Llew's Avatar
Here's the graph options I'm using in DVBDream.
My CPU is a lowly Intel Core2 CPU 4400 2GHz, not a 2.8 I mentioned (that's on my other PC).
Video card an nvidia GEforce 8500GT.
Old 10-07-2008   #8
My System: HTPC
Appreciate you're reply, cheers.
Ive got dvbdream working perrfectly now.
I can only get coreavc codec working perfectly in Dvbdream when the arcsoft codec total media package is installed on my system.....strange
Just need to figure out the best decrypting program now, vplug or s2emu.
Old 10-07-2008   #9
Llew's Avatar
Good news. vplug seems to be the best, updated frequently with v_keys/softcam. It's what I use anyway.
coreavc, progdvb
