Satellite capture - Command lineDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 07-07-2008 Location: Spain
My System: Skystar HD |
Hi!! This is my 1st post in the forum so hello to everyone ![]() I have a Skystar HD card and I'd like to start capturing. Is there any program which allows capturing from the command line?? In other words, do you know any program that can be invoked from DOS command line or Unix systems? I used to use this feature with my old Avermedia for capturing terrestrial TV. The program was Virtual-VCR but it doesn't work for Satellite cards. Any help is appreciated... I'm quite lost and I need to find a solution! | ||
| Member Join Date: 08-02-2008 Location: East Anglia
My System: Dreambox DM800 HD - Sky HD Subscription, Technotrend S2-3200 PCI card. | I have no experience with this but Technotrend supply some tools which allow the TT S2-3200 to emulate a DVB-T antenna for compatability with Windows Media Center, might they also work for you? Found Link - http://technotrend-online.com/downlo....0.5%20x64.zip | ||
| capture, command, line, satellite |
