LNB settings for QPH-031?
Old 30-07-2008   #1
My System: ProgDVB SS2
Hi all, I'm a bit confused on the LNB settings. On the box is says LO 10.75/11.25GHz and with my Mercury II receiver I use a setting of 10750 and it works great and have it locked down on Hispasat 30W.
I'm trying to get ProgDVB to work and have it hooked up the the other L port on the LNB. The default settings for ProgDVB are for a universal LNB and list:
LOF 1 9750 MHz
Switch 11700 MHz
LOF 2 10600 MHz
My questions are do I simply change both the LOF 1 and 2 to 10750?
What is the Switch frequency for?
Thanks for any help in clearing this up for me, SB
stumblebum is offline   Reply With Quote
Old 30-07-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
AFAIK, with this LNB, as you are using one linear port, you only have the one LO frequency (no switch frequency needed as with a Universal LNB) so clicking the custom box in the menu you enter 10750 and leave the other LOF boxes blank.
Try it anyway and see.
Llew is online now   Reply With Quote
Old 30-07-2008   #3
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
Hello!
i have also imported this lnb from usa last year for 150$ now the price is a little bit lower,there is a very big plastic wheater protection slider on my lnb,in europe we dont have this part!
the freqancy range is not the same on linar port,on circular it is a little bit higher,and difrent from orginal freqency,circulat signals on 36 e here very weak at the moment i can only reveive normal kuband signals without any problems
Turok is offline   Reply With Quote
Old 31-07-2008   #4
LOF 1 9750 MHz
Switch 11700 MHz
LOF 2 10600 MHz
Update - looks like I need to give up on ProgDVB for now (SS2 driver issues that I have not been able to resolve).
Trying to get DVBViewer to work instead and used the LOF 1 of 10750 and the other two blank and I think I'm getting close to getting DVBViewer to work. I can get a good solid signal in the transponder status box but I have not been able to make any sense of the channels. I will try to find out more about running DVBViewer and try to make it work.
Got to run, SB
Old 31-07-2008   #5
Turok's Avatar
could it be posible that some circular/linar channels sending in usa invers?
if so maybe you cant change it in the dvb viewer?
lnb, qph031, settings
