Whats "open" - Hotbird
Old 30-08-2008   #1
My System: SKY (FTA) Dual LNB - Hotbird/Astra SkyStar 2 PCI (with ProgDVB) Maybe AtlanticBird if I can find WWE feeds
Hi guys, ive been away from the sat scene for about a year now but have decided to get back into it. I am using a DVB-s card that I have hooked up to Hotbird 13oE (& astra 19.2oE when I get round to aligning it). I also have the option of setting up hispasat (as I did a year ago). Now, my question is, What is "open" at the moment? I know that its a game of catchup, I just want to know what my options are.
Cheers
tw4t is offline   Reply With Quote
Old 03-09-2008   #2
bump ... anyone ? realy need to know so I can get my system up and running (may point to a different sat if hotbird is not an option.)
Old 03-09-2008   #3
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers
Some packages on different satellites are currently open on some receivers (don't know about the PC cards). On Hotbird, Polsat is open and TPS still but only just and not for long; assorted stuff on other satellites eg Premiere on 19E and Digi on 1w.
bigtee is offline   Reply With Quote
Old 03-09-2008   #4
Site administrator
Analoguesat's Avatar
Not much these days - TPS is closing down in a few weeks, and Premiere is midway through switching to the secure NDS encryption!
Theres no point putting a dish on 30W unless you just want the fta channels - the pay services have been secure for months.
Analogue forever!
Old 03-09-2008   #5
Thanks, It just goes to show how much things change in 12months. At one time Hispasat was my Sat of choice. Anyway, What sat would you guys suggest? I realise that more and more providers are going secure, but atm I`ll take what is there ... Cheers
Old 03-09-2008   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
tw4t, (glad that 4's there ), the stuff bigtee mentions can be opened with an emu plugin such as vplug in your chosen viewing application (ProgDVB, DVBDream etc.)
Might find TPS tricky now, used to be OK with the sbcl program, but haven't bothered with that one lately.
Llew is offline   Reply With Quote
Old 03-09-2008   #7
So its basicly a matter of getting vplug running and seeing whats available ... Thats no biggie, should keep me busy over the weekend. just one more question though, Will vplug (with softcam) cover all my needs or will i need any other plugins ?
Thanks Guys
Old 03-09-2008   #8
Llew's Avatar
No, that'll do nicely. No point in cluttering up your plugin folder with other emulators.
Old 03-09-2008   #9
Thanks for the help fellas ...
Old 05-09-2008   #10
Oh well, Managed to get what I can from from Hotbird but no Pron , next step 19.2oE, Fingers crossed for more luck there .....
Old 05-09-2008   #11
Site administrator
The days of free prawn are almost over.
The MultiVision channels on TPS are long gone, and the Premiere "Ab18!" channels will soon be securely black behind NDS.
Analogue forever!
Old 05-09-2008   #12
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
If Vplug doesn't open enough for you then get wincsc (with an up-to-date cfg file).
You might find that you can open whatever you want........ Strictly for educational purposes of course
Low Profile is offline   Reply With Quote
Old 06-09-2008   #13
wincsc , OK not heard of that but Ill google it and give it a go , Thnx
Old 06-09-2008   #14
Alrighty, WinCSC seems like a good program to try, but a google search brought back so many shite results I am unsure what the latest version is, ANY IDEA ? Thanks
v 1.2.0.2483 is the latest I can see but this dates back to 2005 ...
Old 06-09-2008   #15
Llew's Avatar
It's a card sharing program. OK if you have a subbed card to share (and a CI module with your PCI card).
Old 06-09-2008   #16
but not ok if you dont ?
Old 06-09-2008   #17
Llew's Avatar
I don't bother with CS, so can't advise further, sorry.
Old 06-09-2008   #18
1.4.0 Build 2579 is the latest (that I know of).
You don't need a card or any other hardware, it just connects to the servers in your cfg file.
_http://kovsoftnr.webovastranka.sk/
sometimes has cfg files.
The Following User Says Thank You to Low Profile For This Useful Post:
tw4t (06-09-2008)
Old 06-09-2008   #19
Cheers I`ll try it out if I cant sleep tonight or in the morning if I can ...
Old 10-09-2008   #20
My System: Receiver, Satellite
who can tell me what plugin or plugins should i have to decode almost every program?Thx
BetaMax is offline   Reply With Quote
Old 10-09-2008   #21
Site administrator
Its impossible to decode EVERY channel.
Analogue forever!
Old 11-09-2008   #22
k...............thx . ... but someone tell me how to work with wincsc. when i try to import the wincsc.cfg. it just dont recognize it. , and when i try to add it manualy , after i fill all it needs . when i click on get card data it say conection timed out. and i have tried all the adresses/hosts in that wincsc.cfg file
Old 11-09-2008   #23
The card servers aren't always online, and most change passwords daily, so you need to make sure you have an up to date file. It's not always reliable, but sometimes gets a bit extra.
Old 12-09-2008   #24
thx. i think i will stay on vplug then!!!
Old 12-09-2008   #25
yea, ive had no luck with wincsc either. I have been looking into the paid for servers that are advertised on various sites though, what do people here think to paid for card servers ? Are they a rip off ? (I know it defeats the purpose of getting "free" channels but for a few quid a month they promise a LOT) ... and can anyone recomend one if they are decent ...
hotbird, open
