whats the best codec for 422 feeds in progdvb
Old 27-09-2008   #1
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
hi all can anyone tell me the best codecs for 422 feeds in prog dvb please,thanks
iwol is offline   Reply With Quote
Old 27-09-2008   #2
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Most people will say Elecard, a few might say Bitcontrol, but I would suggest installing Nero 8. It will do 4:2:2 and more.
Low Profile is offline   Reply With Quote
Old 28-09-2008   #3
thanks sorted
422, codec, feeds, progdvb
