compro dvb-s 350Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 30-06-2008 Location: heathrow
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap |
i got this card today hoping to watch abit of HD on bbc, but for the life of me i cant get the hd channels. i have powerdvd 8 installed and i can play quite happily hd on wmp as well, but im buggerd if i can can the compro software to see hd channels , i can with dvbdream, but cant watch them no picture.Has any one found any way of getting hd through the software supplied with this card or give me some advice | ||
| Member Join Date: 30-08-2006 Location: Bangalore, INDIA
My System: ApnaDTH Twinhan DVB-S PCI Card. TATA SKY Big TV |
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap | Thanks for the replies chaps, ive got itv and bbc hd now by using coreavc and dvbdream, but i still cant get the hd channels with the software supplied by compro even the lastest updated driver, ive scanned the transponder frequency but it comes back with nothing as far as using a different codec it wont let me change anything , im stuck with compro installed and yes my puter can handle hd![]() Ive just looked at your pic Harrydeo and were its got nvidia codec, mine comes up with "null" no video v6.6.6001.80 18/01/2008 for the nvidia bit i do have a nvidia card GE8600GT so was supprised it isnt showing. ive tried ffd codecs but no joy all it say is something like codec incompatible, so ive stuck with vid: compro audio: compro vmr:R9 speakers: realtek hd coreAVC : H.264 in dvbdream but i would like to get the bloody compro software to work and scan for hd channels![]() Gaz | ||
| | #5 | ||
My System: ApnaDTH Twinhan DVB-S PCI Card. TATA SKY Big TV | I dont understand why you are so keen to use OEM player. Nobody uses it. OEM players are tradition always more stubborn and less features. Thats why we have softwares like ProgDVB, DVBDream, MythTV etc exists. Regarding nvidia codec. That is not a part of Graphics card package. You need to install it separately. Search google for Nvidia PureVideo. Also, you can use Elcard MPEG2 decoder which is bundled with ProgDVB. Ya FFMPEG doesnt work with it. I know. | ||
| The Following User Says Thank You to harrydeo For This Useful Post: | portly (18-10-2008) |
| | #6 | |||
Thanks MR H With regards the compro software, its a matter of principle really, it should work otherwise they are supplying a faulty product Ive had a look at the transponder list under astra 28.2e and im abit confused it goes upto 10921 and then jumps to 11739 me thinks thats not right also it has an lnb choice of ku- cu-universal ect now i have a universal ku lnb, that confused matters ill post a piccy once ive checked how to post them![]() Thanks for yer time | |||
| | #7 | |||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots |
| | #9 | ||
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap | The card works ,just not the software. why do companies supply software that hasnt been tested to the full, I believe this software was designed for xp not vista even though ive used the vista driver/software from there website and they say xp or later.what really gets my goat is compro is a large company ,yet those who make dvbdream can produce a free piece of software that works fine with my card once the right codec was installed ![]() Gaz | ||
| 350, compro, dvbs |
