vista home prem +codecs + dvbdream
Old 20-10-2008   #1
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap
Hi
Has anyone got a codec combination that works with the above "dvbdream" ive tried different codecs to no avail except pure video but it was an older version which kept crashing. all i get is (incompatible codec or renderer combination, graph couldnt be created) i have powerdvd 8 installed and coreavc pro. i can get audio and video on everthing "sometimes"except hd channels even though i get the incompatible warning please help i want to punch the screen
portly is offline   Reply With Quote
Old 20-10-2008   #2
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Have you tried VLC? I'm not sure whether or not it will work with what you are attempting, but it has lost of built in codecs which might help.
_http://www.videolan.org/vlc/
compufunk is offline   Reply With Quote
Old 20-10-2008   #3
harrydeo's Avatar
My System: ApnaDTH Twinhan DVB-S PCI Card. TATA SKY Big TV
Originally Posted by portly View Post
Hi
Strange to know that CoreAVC is not working for you.
Have you tried playing any x264 files.
While playing x264 files make sure that graph looks similar to this.
For HD you always have to work with CoreAVC, thats the best.
AdminPlease adhere to the forum rules and do not link to images on other sites upload them to this site using the manage files option lower down the posting page
Got it
harrydeo is offline   Reply With Quote
Old 21-10-2008   #4
I managed to get hd working ,after getting rid of all the installed codec packs, uninstalling pdvd8,dvbdream and the driver for the compro s350 then i reinstalled with only one codec pack and coreavc and it works for the moment
this is what im using at the moment.
video codec= gabest mpg2dec
audio codec=fddshow
video renderer=wmr9
audio renderer= default direct sound
H.264 = coreavc v1.8.5.0
There are very little codecs to play with in the drop down lists and when i do it goes belly up with the warning coming up again so it looks as though im stuck with this lot , not the best but hay they work
OH the audio codec ,drop down list is pink????? got a clue for that one?
Old 21-10-2008   #5
harrydeo's Avatar
Pink means the codec is not compatible. Try changing it the value.
The Following User Says Thank You to harrydeo For This Useful Post:
portly (22-10-2008)
Old 22-10-2008   #6
What do you mean changing the value , Mr H and were do i change the value
If you mean changing to a different codec in the drop down box , then it wont work they are all pink Cheers Gaz
Old 28-11-2008   #7
Hi
I am using Cyberlink videocodec and audio codec that came with power dvd mediaplayer using vmr 9 ,never had any playback problems using this combination
paulipm is offline   Reply With Quote
codecs, dvbdream, home, prem, vista
