vplug | |
| Regular Member Join Date: 30-06-2008 Location: heathrow
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap |
is there a guide to using this prog anywhere ![]() Ta Gaz | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Not sure how transferable the knowledge is to your needs: http://www.satellites.co.uk/satellit...50-post41.html | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | For the basic vplug emulator without the SBCL plugin referred to by mhku, it just runs in the background of your DVB application; provided you have up-to-date keyfiles in the plugins folder, it'll work without any input from you. Clicking on Show Monitor in the Plugin box of your running application gives you several tabs that allow you to update transponders and import keys. There's also an editor at the end that allows you to check and change parameters of channels, add and edit softcams etc. Llew | ||
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap | Cheers chaps, i am thinking of using it with my pc card compro s350 and dvbdream, but its strange that a plugin is produced with no info on how to use it and seeing as im new to this sort of thing , its rather confusing | ||
| vplug |
