ITV HD and Skystar HD2
Old 03-11-2008   #1
My System: .
Has anybody managed to get ITV HD open with a Skystar HD 2? I would be interested to know how they have gone about doing it, is so. I am using DVB Viewer as my software.
You Knows It is offline   Reply With Quote
Old 03-11-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
OK with DVBViewer Pro. Should be OK with DVB Viewer too. As long as you have the correct parameters as in the pic, you should have no problem.
Last edited by Llew; 03-11-2008 at 11:06 PM. Reason: Moved posts to appropriate section.
Llew is offline   Reply With Quote
The Following User Says Thank You to Llew For This Useful Post:
You Knows It (03-11-2008)
Old 03-11-2008   #3
My System: .
I found a .ini that contained the following text and I managed to open it using that. I'd tried some of the other .ini files using dvbviewer and SS HD2 but none of them worked except the one I posted below.
[Channel0]
TunerType=1
Frequency=11428
Polarity=h
Symbolrate=27500
FEC=1
APID=3402
Language=eng
VPID=3401
PMTPID=3400
PCRPID=3401
AC3=17
TelePID=0
SID=10510
StreamID=2315
NetworkID=2
LNB-Selection=0
LNB=9750
DiseqC=6
Root=Astra 28° E
Name=ITV HD
Category=BSkyB
Encrypted=26
SatModulation=0
Group=1
AudioChannel=0
*edit* Didn't see your pic above, Llew, looks like yours is the same data. Thanks for your time.
Old 04-11-2008   #4
Llew's Avatar
More than one way of killing a cat
Glad you got it working. Just need some decent programmes now
Old 06-11-2008   #5
My System: skystar2
is skystar hd2 compatible with AltDVB and Vplug.?
zeeshan8808 is offline   Reply With Quote
Old 07-11-2008   #6
Llew's Avatar
I could never find a BDA driver that worked with AltDVB using SS HD2.
Maybe there's one out there somewhere. Same with DVBDream.
Works fine for me withDVBViewer Pro. ProgDVB Pro OK too on a good day when it doesn't crash (probably my setup).
No doubt VPlug will work if you do manage to find a driver eventually.
Old 07-11-2008   #7
My System: skystar2
Many thanks Llew.
Old 07-11-2008   #8
My System: skystar2
Llew which one do you think is the better skystar hd2 or twinhan azurewave sp400 or are they both 100% identical.
Old 07-11-2008   #9
Llew's Avatar
Yes, the SSHD2 is a rebadge of the Azurewave. both use the Mantis driver.
Don't know the application s/w of the Azurewave, I might see if it works with the SS2.
Old 08-11-2008   #10
My System: MULTI SATELLITE
I dont know whether this helps, but there is a replacement bda device driver available for altdvb that supports the azurewave, I use it with mine.
zarquon is offline   Reply With Quote
Old 09-11-2008   #11
Llew's Avatar
Thanks, did try that one but the SS2 HD2 is not recognised using that in my AltDVB.
There's a difference in the subsystem IDs between the two cards, as I tried to use the Skystar in Linux and had to change the IDs from the Azurewave's to mine for the card to be recognised. How this is achieved in XP or whether it can be done I don't know.
For Linux, see _http://tinyurl.com/5j9net
Old 09-11-2008   #12
My System: Topfield 7710 HD PVR, Humax HDCI2000 HD Triax 1.1m (on 0.8w), Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2
Hi Llew
Is ITV HD still working for you?
down for me on Topfield have they changed freq or ID's?
Jem
Don't bother checking as it's back to usual not available message on screen, much better!
developers is offline   Reply With Quote
Old 09-11-2008   #13
Llew's Avatar
Just checked, affirmative
Old 09-11-2008   #14
Yes - I think it must be they were having a whip round for money for the elec meter, watching Brittania High in HD now.
Jem
hd2, itv, skystar
