compro lnb settingsDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 30-06-2008 Location: heathrow
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap |
Im trying to get compro DTV2.5 to access the hd frequencies, which at the moment it wont, for some reason it jumps the frequencies.This maybe down to the lnb settings? I have a universal ku band lnb with the following in and outputs Input : 10.70 - 12.75 ghz Output : 950 - 2150 mhz Below is a piccy of the compro setup scene. what settings should i put in the lnb section. i have a single dish and lnb fixed at astra and eurobird 28.5 Thanks Gaz | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Does your card have a DVB-S or DVB-S2 tuner? If the former, you won't be finding any HD channels except possibly those using DVB-S and MPEG4 video (such as ITV HD). Llew | ||
| | #3 | |||
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap | I can get bbc hd itv hd (finally)and luxe hd with dvbdream but not with the compro software itself, for some reason it jumps past the bbc hd frequencies when you do a simple scan and dosnt show up when you try a transponder scan? me thought it might be the lnb settings.It is a dvb-s card Cheers Gaz | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | LNB settings are OK. Can't see what your problem is there. You should certainly get the other channels on the10847V TP. I'd stick with DVBDream. Llew | ||
| compro, lnb, settings |
