Software Satellite MeterDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 07-07-2004
Hi all, I am looking for a software satellite meter that runs on PC with installed satellite PC card. ![]() I want to show the signal strength of each satellite transponder exactly the same way as any regular signal meter does (i.e. bins aligned across the display). Speed of tracking is not a problem as the displayed graphs will not be used to detect satellites but to compare the signal received using different LNBFs. This task is a part of a bigger project to design better feedhorns and assure the correct design using frequency analysis graphs. Sorry if the question is stupid but I am completely illiterate about satellite PC cards and their drivers. Any ideas ??? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | This may help _http://www.fastsatfinder.com/ | ||
| Hi, Fast Sat Finder is a pretty cool program with many snazzy features. HOWEVER, I will be happier if I can log the transponders strength and quality in an ASCII file that can be imported to other data processing programs. Although this requirement seems so picky but it is important in my field. | ||
| | #5 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Also shold be noted, fastsatfinder often "detects" signal, where it's totally absent! I prefer Setup4PC for such tasks. In addition to signal strength, gives me SNR and BER information. | ||
| meter, satellite, software |
