No signal fron skystar 2 PCI card
Old 10-11-2008   #1
My System: sky digi box mini dish
I have 80cm raven dish with quad LNB, I only use one connection from the quad LNB, winxp, I receive all the FTV channels, my tely packed in, so I thought I'll watch tv on my pc, I installed the Skystar 2 but Its says no signal I know I'm getting a signal so why is the tv card saying no signal
juandan is offline   Reply With Quote
Old 10-11-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Which application are you using? (DVBViewer, ProgDVB or...?)
Llew is offline   Reply With Quote
Old 10-11-2008   #3
Hi, I'm not using any application, after I installed the skystar 2 software I clicked on the red Icon in system tray and it said no signal, I have since loaned a tv from a friend just to do a signal test on my sky digi box and I'm getting a good signal from the dish, i'm new to tv cards so I don't really know what I'm doing, on the install cd it says the manual is on the cd but when I run the cd again it just wants to install again
Old 10-11-2008   #4
Llew's Avatar
Clicking on the red icon gets you Technisat's Setup4pc's software which is auto installed on using the Skystar. Don't bother with it. Your CD should allow you to install the basic DVBViewer. Or search for a more versatile application such as ProgDVB 0r DVBDream, both free.
Old 10-11-2008   #5
Thanks for that I will try it but I can't tonight as my grandaughter is watching the on the loaded tv, I only have one coax cable and thats back in the sky digi box, I bought the card on Ebay and just noticed the Infra-red receiver for the remote is missing, so I might be sending it back
Old 12-11-2008   #6
Don't I first have to get a signal? as I say the card is saying no signal , I thought the DVBviewer is for viewing the picture
Old 12-11-2008   #7
Llew's Avatar
DVBViewer (or any other viewer) will set up your card to receive the signal from your dish.
In DVBViewer, click on Options - hardware to see that Skystar2 is listed.
Click on Channel - channellist in the top bar and choose Astra 28E and find a FTA channel to view.
Old 30-11-2008   #8
Sorry for taking so long to reply, in the end I sold the card,
thanks for your help
Old 21-03-2009   #9
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
Is your motherboard Nvidia chipset based?
BombedOne is offline   Reply With Quote
Old 23-03-2009   #10
My System: Technisat
no. I am using Intel integrated graphics card.
qwerty is offline   Reply With Quote
Old 23-03-2009   #11
Amo Amas Amant Admin
Topper's Avatar
Please
The discussion on the skystar 1 USB has no relevance on this thread so I have split it off to it's own thread
http://www.satellites.co.uk/satellit...tar-1-usb.html
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
card, fron, pci, signal, skystar
