Technisat Skystar2
Old 21-11-2008   #1
My System: 12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300.
Technisat Skystar2
Dear Members,
Is the Technisat Skystar2 V.2.6 PCI Card is capable of decoding DVB-S2 signals.
selvam is offline   Reply With Quote
Old 21-11-2008   #2
Archived Member
Originally Posted by selvam View Post
Dear Members,
No.
You will need SkyStar HD2
_http://www.technisat.com/index4986.html?nav=PC_products,en,76-215
HB13DISH is offline   Reply With Quote
Old 21-11-2008   #3
Originally Posted by HB13DISH View Post
No.
Dear HB13DISH,
Thanks for your advice and reply.
Old 23-01-2009   #4
My System: skystar HD 1080i sat +pci cam card. vista premium 32bit, geforce 8800 gtx directx 10
Thumbs down
hi i have a skystar hd2 how do i get itvhd or ch4hd and they are not found when i do a scan can anyone help me
leebobslee is offline   Reply With Quote
Old 24-01-2009   #5
Archived Member
Does your PC meet the system requirements of the card?
Vista Premium?
Old 24-01-2009   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Shouldn't have any problems scanning those channels in if you're correctly pointing to Astra 28E.
For ITV HD, enter the parameters shown here in your application (presumably DVBviewer, but will be similar for others).
You won't open Ch4 HD unless you have a CI module married to your Skystar HD2 in which to use an appropriate CAM and Sky card.
Llew is offline   Reply With Quote
Old 24-01-2009   #7
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
I've managed to decode HD feeds by reducing my screen quality to 16bit and reducing the screen resolution to 800x600.
Kind of defeats the object if a non HD signal is available though.
Low Profile is offline   Reply With Quote
Old 24-01-2009   #8
Archived Member
Yes, but perhaps you can record HD channels instead of SD
Old 24-01-2009   #9
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
if you want to make blindscan ,with the skystar 2 make sure you buy version 2,3C,all later version and revisions ,are not compatible,with this nice blindscan tool!
Turok is offline   Reply With Quote
Old 24-01-2009   #10
Re 2.3
It's a shame that Altx's blindscan tool doesn't work with later drivers.
Bxs will work (so long as you have Setup4PC running), but it doesn't have dynamic fine tuning (dependant on the S/R) like Altx's does.
You can also blindscan using DVBDream if you set up a transponder ini file without symbol rates like this:
1=10715,H,0
2=10727,H,0
3=10739,H,0
4=10751,H,0
Old 26-01-2009   #11
my (skystar hd dvb s2 mpeg 4 with cam) can only get the bbc hd(ch)my TechniSat TV Center seems ok and my dish seems fine to ,is TechniSat TV Center,anygood,if not what is and were do i get it .DVBviewer will not work with my vista 32 bit i can make it worc on xp only???
Old 26-01-2009   #12
Llew's Avatar
I use DVBViewer Pro -
_http://www.dvbviewer.com/en/index.php
Works well with the Skystar.
Others to try are DVBDream, ProgDVB or AltDVB.
Old 26-01-2009   #13
(Thanks) but still4 no joy, i have dvbviewer,CyberLink PowerCinema,DVB Dream,TechniSat TV Center, and ProgDVB 6 can,t see the card .I can see ch 4 hd now on (sky bsb)( blocked) but no itv hd.
Old 26-01-2009   #14
Turok's Avatar
can someone upload,all this tools,here,or a link to a website,i dont have tested them all yet
Old 26-01-2009   #15
Llew's Avatar
No problem with my DVBViewer Pro. You can receive Brit Shorts on that frequency I assume. Change the parameters as posted before, rename it ITV HD and click 'Add' to place it in your channel list on the left.
Showing ITV programming ATM.
Old 04-02-2009   #16
(thanks) i got itv hd to work but now it will not work ?
Old 04-02-2009   #17
guest
Posts: n/a
Air time is really very sparse at present, so it's there when it's there!
Here's the latest schedule:
Wed 4th 8pm FA Cup: Everton v Liverpool
Thu 5th 9pm Piers Morgan On...
Sun 8th 8.30pm Wild at Heart
Sun 8th 11.15pm Film: Shakespeare in Love
Wed 11th 8.30pm Football: Spain v England
Thu 12th 9pm Piers Morgan On...
Sat 14th 12.10pm FA Cup: Swansea City v Fulham
Sun 15th 4pm FA Cup: Derby County or Nottingham Forest v Manchester United
Sun 15th 8.30pm Wild at Heart
Mon 16th 10.35pm Film: American Pie
Wed 18th 10.35pm Film: American Pie 2
Thu 19th 9pm Billy Connolly Journey to the Edge of the World
Old 04-02-2009   #18
Llew's Avatar
Between advertised programmes, a station ident is usually shown (not always though).
Old 04-02-2009   #19
Cool ITV HD-skystar hd-dvbviewer
(BIG THANKS) your the main man .It dose work,can you get me any more itv hd times if not were from. ps (THANKS)
Old 04-02-2009   #20
Llew's Avatar
Glad you've got it working OK.
A regular check of this site has forthcoming programme details -
_http://www.joinfreesat.co.uk/index.php/freesat-channels/itv-hd-schedule
The Following User Says Thank You to Llew For This Useful Post:
leebobslee (04-02-2009)
skystar2, technisat
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
