I'm Sooooo Odiot.......!!!
Old 18-12-2008   #1
My System: Skymaster Dish 80cm with skystar 2. Intel Q6600 - 4GB Ram - Asus Maximus Formula - XFX 8800GTS 640MB Alpha Dog Edition - Vista x64
Unhappy I'm Sooooo Odiot.......!!!
Hi everyone,
yesterday I bought skystar 2 and as I saw at "idiot guides" I downloaded ProgDVB 6.02 and DVBviewer PRO 3.9.4.0, so I am trying to use these programs with "softcam.17.dec.2008" which I downloaded but I don't know how!! I downloaded the latest version from Yankse-1-31.0-TT-XP but it doesn't work cause I have vista x64.
I'm completely idiot cause I have search so much for a guide to use softcam keys and software and I don't have understand nothing!
If someone know and have time please send me a simple guide about
PROGDVB or DVBVIEWER.
Merry Christmas to EveryONE!!
mariosk1gr is offline   Reply With Quote
Old 18-12-2008   #2
My System: 43cm @ 19.2 with mVision USB PVR, 1.1m Fortec Star @ 5e and 1w with Kworld DVB-S2 Card and a Viasat receiver
Originally Posted by mariosk1gr View Post
Hi everyone,
Download vPlugin with latest keys, its much better and easier to use, just install it to the DIR of ProgDVB plugins and it will work.
iandoh is offline   Reply With Quote
The Following User Says Thank You to iandoh For This Useful Post:
mariosk1gr (19-12-2008)
Old 18-12-2008   #3
Question Thanks..
Ok So do u know where can i find it?? I tried dvbsoft.net but no luck.
When I download it I just put it only to progDVB dir?? no settings?
Thanks in advance my friend iandoh!
Old 18-12-2008   #4
Archived Member
Which satellites are you pointing to?
I suppose Hot Bird 13E judging from your location.
Perhaps I am mistaken, but AFAIK there is nothing there worth the trouble.
HB13DISH is offline   Reply With Quote
The Following User Says Thank You to HB13DISH For This Useful Post:
Old 18-12-2008   #5
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Best to go to vplug's main site -
_http://vplug.baywords.com/
Yes, just put it in the ProgDVB's plugin folder. You'll need to update v_keys, search for the latest one.
Llew is offline   Reply With Quote
The Following User Says Thank You to Llew For This Useful Post:
Old 18-12-2008   #6
Thumbs up I think I'm ready, am I?
Yes I'm pointing at Hotbird 13o East.
Ok So I uninstalled everything cause was a mess and started from the
beginning!
So,
1. I Installed ProgDVB 6.02 x64.
2. I put into "plugins" folder v_keys.db (3/12/08).
3. I installed vplug 2.3.9
4. I put into "plugins" folder softcam.key (17/12/08).
Final: Do I need something else to do???
Very many thanks for ur help guys, be well!
Old 19-12-2008   #7
Cool Nothing yet... what am I doing wrong?
So, can someone (plzzzzz) tell me where am I wrong??
As u have seen in the preview msg I have done these steps that u have told me to do. Am I missing something with the settings on ProgBVD 6.02? A little help if u can guys...
Old 19-12-2008   #8
Llew's Avatar
Click on the Plugins tab when you start ProDVB and tick vplug and monitor.
Haven't checked lately, but as has been mentioned, not much you can clear on 13E now.
Old 19-12-2008   #9
Archived Member
There is nothing on Hot Bird 13E.
Which channels are you after?
Old 19-12-2008   #10
Cool Pity pity pity....
As I have checked in my country most people set their dishes to 2 specific satellites: Astra and Hotbird.
So u tell me that ProgDVB and plugins can't u***ck channels on hotbird!
Damn it, I don't know if I can set my dish to another satellites cause I don't know if it is possible to do from my country (Greecce)...
Until now I'm watching only fta channels and I'm trying to see movie channels like nova - filmnet - supersport and others. Guys can u suggest me a solution plz........? I'm Lost for one more time again!!!
Old 19-12-2008   #11
Sotos65's Avatar
My System: Receivers: Edision Argus, Technomate TM-5300D+ USB, Skystar HD2 Dish: Tecatel 1.10X1.20 LNB: Sharp BS1REL100W Sat motor: Moteck SG2100 PC: Cpu C2D E8400, 2GB.
Unless you have obstacles (trees, buildings) in front of your dish, there is nothing to prevent you to set it up on another satellite.
I guess you're out of luck! There is not much left to see with plugins like vplug (or with emus on set top boxes) at this time. The only important package that is left "open" is "Digi TV" on Thor/Intelsat 7-10 at 1°W.
Sotos65 is offline   Reply With Quote
The Following User Says Thank You to Sotos65 For This Useful Post:
mariosk1gr (20-12-2008)
Old 19-12-2008   #12
Smile
Ela re Soto epitelous enas ellhnas na sunennoitho san anthrwpos!!!
Na sou pw file mou efoson vevaia den ginomai "varos", mporeis na mou eksigiseis peripou pws doulevei to susthma me thn skystar 2 k to xekleidwma tvn kanaliwn? H alhtheia einai oti exw ena poly fthno piato 80cm to opoio to eixa parei set me enan apokodikopoihth ths plakas k epeidh prosfata anevasa to piato sth taratsa k perasa to shma se oles tis prizes tou spitiou skefthka na parw th sygkekrimeni karta gia na vlepw dwrean ta apokodikopoihmena...
Apo oti diavasa se forum ke meta apo poli psaksimo eida oti h skystar exei autes tis "dunatothtes" opote k proxwrhsa stin agora tis!
Telos olo auti to epixeirhsa skeptomenos me to "xazo" mou to myalo oti tha vlepw tainies mias pou eimai cinefil, podosfairo kana ntokumanter k.a.
Kai se rwtaw egw twra: is it possible???
Old 19-12-2008   #13
Sotos65's Avatar
Είναι δυνατό (το vplug δουλεύει ή μάλλον δούλευε πολύ καλά, και δεν έχει να κάνει με δυνατότητες της συγκεκριμένης κάρτας μόνο, δουλεύει και με άλλες κάρτες, αλλά με τα διάφορα προγράμματα που χρησιμοποιούμε), αλλά έπεσες στην περίοδο των ισχνών αγελάδων που σχεδόν όλα τα πακέτα (Premiere, Polsat πήγαν σε nagravision 3, TPS φεύγει από Hotbird και πάει στον Astra με αλλαγή κωδικοποίησης, κλπ) έχουν κλείσει το τελευταίο δίμηνο! Κάποια σκόρπια έμειναν εδώ και εκεί, αλλά τίποτα το αξιόλογο εκτός από το Digi TV που μάλλον κι αυτό θα περάσει σε nagravision 3 κάποια στιγμή.
PS. Sorry for the greek!
Old 20-12-2008   #14
Llew's Avatar
Enough already - English in this section please.
Old 20-12-2008   #15
Unhappy Sorry
Sorry for the greek.
If I have understand correct, nagravision, TPS, seca and others are decryption systems to secure the channels right? So where to put my dish u suggest??
What do u think about NOVA? Can it be??
Old 20-12-2008   #16
Archived Member
No, TPS is a French package and it will leave Hot Bird 13E by the end of this year. Nagravision, Seca are encryption systems.
Nova is secured with Irdeto.
Old 20-12-2008   #17
Cool
thank u for the info!
I opened my pc before and when I try now to run progDVB it says "device not started!
Here is a look......
And some info about the software and the system..
So any ideas...??
I have getting tired with all this story....
Old 20-12-2008   #18
Ok I fixed by installing 32bit version, for some reason 64bit doesn't play!
So, until now I have put many plugins into "plugins folder" but how can I know what have I un****ed??
Take a look:
I have lost plz a little help guys........
So many channels..... How shall I know if i have done anything???
Old 21-12-2008   #19
SOTOS65 if u can send me ur email to contact with u if u like.
Old 21-12-2008   #20
Llew's Avatar
Too much unwanted files in your Plugins.
You only need those I have in the snapshot.
The channels with a red icon are the encrypted ones. The only encrypted channel I can open on 13E is the one in the pic. Possibly it's clear ATM anyway
Forget 13E, nothing doing now.
mariosk1gr (21-12-2008)
Old 21-12-2008   #21
Sotos65's Avatar
Actually you don't need all those files in every application (AltDVB, Progdvb, DVBViewer, etc), you only need two, vplug.dll and vplug.ini.
You install vplug in a separate folder (anywhere you like, the default is C:\dvbapps\vplug) and you only need to copy those two files in the dvb application plugins folder. There is just one more thing to be done, you have to edit vplug.ini (with a simple text editor, like notepad) and put the vplug's installation path in "FilesPath=" (without quotes), like this for example,
FilesPath=E:\DVB\vplug
Anyway, as others have already said, there is not much to see (at least on Hotbird).
Old 21-12-2008   #22
Thumbs up
Ok, very helpful ur info, thank u.
So, vplug is the trick. What about softcam.key?Do I need it?
How I know what channels have unlo***d?
And.. last question in what sat do u suggest to install my dish??
Old 21-12-2008   #23
Sotos65's Avatar
There is no need for softcam.key, only v_keys.db is needed. But you may import a softcam.key in v_keys.db (if it contains something new) using vplug's editor. Right click vplug's icon in the tray (the yellow disk), select "editor", go to the "keys" tab, and from "import softcam.key" you may import a fresh softcam.key. There is the possibility to delete older keys or import only new ones.
Old 21-12-2008   #24
Red face
How should I know what channels have unlo***d?
Is Astra a good sat?
It is a little complicated the whole thing about keys - sats - software, so does anyone know where to find a "simple guide about all these things which we r talking about"?
odiot, sooooo
