Skystar-2 PCIDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 14-10-2005 Location: .
My System: 12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300. |
Dear Members, I am having the 13/18 switching fault in my Skystar-2 PCI.v2.6d. Always i am getting 18 Volts output to LNB, so i am unable to tune the vertical tramsponders in C-Band. Please any one may provide the schematic for the above. | ||
| | #2 | |||
Please help me fo get schematic diagram of Technisat Skystar-2 PCI.v2.6d. | |||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Try to google it. I also have it somewhere at home, will try later to find... | ||
My System: 12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300. | | ||
| | #5 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Here it is: _ttp://andrez04.net/SXEMI/ss2v26bpower0hi_171.jpg | ||
| | #6 | ||
My System: 12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300. | Dear BombedOne, Thanks for your reply. But in the diagram it belongs to Skystar-2 V2.6b. power supply. Is there any difference in power supply between V2.6b & V2.6d | ||
| | #8 | ||
| | #9 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Generaly you need to replace Q6 (as on above schematics). Better to use some more powerfull MOSFET. | ||
| | #10 | ||
| | #11 | |||
My System: 12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300. | Please mention the (Manufacturer & Number) of some more powerfull MOSFET, for replacement of existing MOSFET in Skystar V.2.6d. Your help in this regard is very much expected. Sorry for my poor English | |||
| | #12 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | If you already can't guess, that means that your electronics knowledge is very poor, so to avoid future damage to card, it'll be better to show it to some specialist. | ||
| pci, skystar2 |
