multi satellite card in one pc
Old 05-01-2009   #1
My System: twinhan card
hello every one,,, i have four satellite cards,,,3 twinhan and one technisat,, is it possible to all of them to work in the same time...i mean in one pc?
i need to capture from the 4 cards in the same time
and if so..is there any software that can run multiple time like virtualdub but for satellite cards,,,?
mgm21m is offline   Reply With Quote
Old 05-01-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum mgm21m
In answer to your question I am almost certain the answer is no since a PC would not have enough processing power. You could use a quad output lnb to supply them however the processing power of even a top of the range PC could not cope with four cards at the same time and recording as well
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 05-01-2009   #3
thanks topper,,,anyway i have two processors zeon and the processing is not important all i need is a software with multiple copy,,,like virtual dub ...software can open more than one time,,,is there any software can open more than one time???
Old 05-01-2009   #4
rolfw's Avatar
Real name: Rolf
My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Spectrum analyser.
I would also have serious doubt as to whether the pc will be capable of powering 4 LNBs.
Rolf
Old 05-01-2009   #5
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Not sure that processing power would be an issue if recording FTA channels....I have 1 x DVB-S and 2 x DVB-T and can record 3 programmes simultaneously on a 2.8GHz P4. Power requirements for the LNBs may be an issue, but presumably that could be overcome using a quattro with a powered switch (assuming all channels from the same sat)?
pgh13 is offline   Reply With Quote
Old 05-01-2009   #6
jphili's Avatar
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception from HB Astra 1 and 2 + TopField TF 7700 HDPVR + TwinHan VisionDTV
When just recording the processing requirements should not be that high. Most of the processing requirements for an HTPC are for the MPEG2/4 decoding and that's only needed when viewing.
I/O bandwith might become an issue at some time, especially if all those streams are sharing the PCI bus.
So the more of those tuners are PCI Express, the less issues you can expect.
You might want to have a look at mythtv. You could try to set up your box with 4 tuners as master and run different clients when you want to view.
jphili is offline   Reply With Quote
Old 05-01-2009   #7
Or if you are more Windows orientated; take a look at GBPVR
card, multi, satellite
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
