PCMCIA Extension .. ???Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Guest
Posts: n/a
Hi .. I have the Galaxis DVB-Sat PCI card , which is one of the TechnoTrend and siemens family .. and in addition .. I have the CI Extension adapter .. Now my question is : Can we use this Extension to upgrade the CI modules instead of using the Notebooks .. ?? IS there a specific software for it . ?? and HOW ?? Or we are forced to buy another PCMCIA adapter inorder to upgrade the Cams .. ?? and if yes .. where to find these adapters .. ?? Regards Luis | ||
| Guest
Posts: n/a
I don't think so! The software that is used to update the CAM must have been written to address the pcmcia bus but the CI module is connected to the DVB card. In the past I have seen PCMCIA adapters for desktop pc's but not recently but they are proably still available. Why not use an old notebook pc? However, I am not sure about the long term aspect of this method anyway. The CAM's use flash memory that has a lifetime of about 1000 re-writes and the CAM costs £80. Furthermore rewritable CAM's are no longer available. The alternative is to use a wafer card which costs from £8 to £15. You need a programmer as well but that costs about £60. Jim | ||
| Guest
Posts: n/a
Well .. I have got all the equipments that you mentioned . And actually I have 2 CI cams with old versions .. I want to upgrade them to the new versions like 4.6SE etc ... If you can help me to find any kind of stores that sell these type of adapters, I will be very appreciated .. The other thing .. Is there any kind of software around , to make the DVB-Sat PCI card to emulate Irde*o packages .. since it is directly connected to a PCI bus .. I have seen the WINDVBLIVE software that is written for this family of cards .. and it has very nice features but it doesnt have built in Emulater .. Any idea ????? Regards Luis | ||
| extension, pcmcia |
Similar Threads | ||||
| Problem patching Reality CAM using laptop PCMCIA | Anbeyon | Cams and decoders General | 11 | 08-01-2008 08:52 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| PCMCIA Port on Laptop | km21 | Matrix Reloaded, Revolutions and CAS interface | 7 | 13-03-2005 05:38 PM |
| PCMCIA Error | bigboogaloo | Matrix Reloaded, Revolutions and CAS interface | 5 | 22-11-2004 11:03 AM |
| PCMCIA Connection to Network | wolsty | Computer Discussion | 7 | 23-09-2003 12:25 PM |
