Warning: technotrend 3650 & Diablo cam
Old 12-02-2009   #1
My System: VISTA ULTIM AMD 5600 X2 2GB Memory Technotrend 3650 CI DVB-S2 Compro 350 DVB-S Hauppauge 900 DVB-T NVIDIA GeForce 7600 And this doesnt' work the way I want it too. :(
Just a word of warning I purchased a Diablo CAM for use in my Technotrend 3650ci only to discover that the Technotrend 3650ci is not compatiable with a Diablo CAM.
Anyone thinking of purchasing a Technotrend 3650ci I would strongly advise them against. I've had nothing but problems since I first purchased and the lack of support from Technotrend is ridiculous.
They just got round to publishing drivers for the Vista TV Pack 2008 and an update to thier TT Decoder to allow the decoding of tv in VMC. Unfortunately they only publish instructions in German which dosent translate very well via Google translate.
Emails to them often get ignored. So I struggle on.
It seems that if I want to view any CONAX channels I'm going down the T-Rex cam, which does work, and an MII+ card. Hopefully this will be my problem solved.
Mickey
mickeymci is offline   Reply With Quote
conax, diablo, mii+, technotrend
