Is my Skystar HD2 DOA?
Old 14-02-2009   #1
My System: Vista 32 bit, Core2Duo 2.4MHz, Technisat Skystar HD2
Hi just want to confirm if my Skystar HD2 is faulty or not.
We are set up to receive Sky+ HD in our living room. When it was installed I asked for a connection to be wired from the dish to my bedroom.
I bought the Technisat Skystar HD2 to receive Freesat on my PC in my bedroom. However I get no channels. Card and drivers install fine (latest software downloaded from _www.technisat.com, version 1.2 and DVBViewer TE2 beta).
Here is a picture from the channel scan section:
As you can see no channels found - is it me or the card?
N.B. I have managed to receive BBC One with a Hauppage WinTV Nova-S, so it would seem the cable is not at fault.
ModerationUploaded image as attachment for you. Please read the rules regarding image code - SM
Bogalvator is offline   Reply With Quote
Old 14-02-2009   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Sometimes you need to click on 'Scan Devices' in Options - Hardware to get it the driver to kick in.
Llew is offline   Reply With Quote
Old 16-02-2009   #3
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
I never be able to receive ANY channel using technisat software!
just instal DVBdream and things will go on.
BombedOne is offline   Reply With Quote
Old 16-02-2009   #4
Llew's Avatar
Transedit from DVBViewer Pro's site gives you a much better TP scanning facility than the plain vanilla DVBViewer. Need to buy the Pro version, but well worth the price.
Old 01-03-2009   #5
Well tried the above tips to no avail so returned the item and had it replaced. Now DVBViewer and DVBDream etc work fine, so original card was indeed faulty.
Cheers for the pointers.
Old 01-03-2009   #6
Llew's Avatar
Glad you got it up and running, duff tuner on the old one possibly
Old 01-03-2009   #7
My System: dvb s2 usb for pc
I am getting problem in channel scanning, many time installed & removed drivers and software and installed card in different slot. also tried dvbdream and dvb viewer pro. tried through fast sat finder software as well.
any trick from which I can confirm that my card is faulty or I am making mistakes in configuration?
krishn is offline   Reply With Quote
doa, hd2, skystar
