CAS 3 ProgrammerDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 29-07-2008 Location: Scotland
My System: VISTA ULTIM AMD 5600 X2 2GB Memory Technotrend 3650 CI DVB-S2 Compro 350 DVB-S Hauppauge 900 DVB-T NVIDIA GeForce 7600 And this doesnt' work the way I want it too. :( |
I have a CAS 3 programmer with USB and Serial connections. In my PC I have a DVB-S (Compro 350) card. Which does not have a card interface. Is it possible to use the CAS 3 programmer as a card interface, i.e. insert my T-Rex cam into the CAS 3 to view channels. mickey | ||
| Member Join Date: 08-02-2008 Location: East Anglia
My System: Dreambox DM800 HD - Sky HD Subscription, Technotrend S2-3200 PCI card. | Yes, If I remember correctly you need to use the serial connection to do this though and set it up in CAS Studio (not sure but think 3.68 MHz?? Anyone know for sure?) I was considering the same a while ago and was not able to use as didn't have serial connection on my new motherboard. I am looking into what smartcard reader to get instead now. | ||
| Member Join Date: 05-09-2008 Location: Hampshire, UK
My System: Fortec Star FS-4200, Comag SL30/12, Triax TD110 dish, Jaeger99 motor, AzureWave AD-SP400 PCI card (Twinhan thing) | If your PC doesn't have a 9 pin RS232 serial port on it, surely one of these would do the job? _http://www.maplin.co.uk/Module.aspx?ModuleNo=29968 I've never used a card programmer before, so I couldnt say how compatible these are with USB to serial adaptors (drivers wise), but it might be worth a go? | ||
| Regular Member Join Date: 18-10-2005 Location: BE
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception from HB Astra 1 and 2 + TopField TF 7700 HDPVR + TwinHan VisionDTV | It is possible to use the CAS 3 serial interface to 'debug' a CAM. I've only used it to bring up the CAM menu so far, but it should support all it's functionality. With regards to USB-Serial converters, these do not always work as they should. It depends on the usage of the serial connection. When you're streaming data, there shouldn't be an issue. But sometimes there's extensive usage of the control pins and then the latency of the converter can be an issue and bring performance to it's knees completely rendering it unusable in some usage scenarios. An alternative way to use subscription cards is to use a CAM emulation (i.e. Poor Man's CAM 2 _http://joshyfun.peque.org/PMCAM2/index.html) together with an USB card reader like the Infinity USB unlimited ( _http://www.infinityusb.com/ ). | ||
| | #5 | |||
| Member Join Date: 27-11-2008 Location: Israel
My System: HTPC with Sky Star HD Card. Viaccess CAM for Swiss channels on Hotbird 13E. | How can I connect Cas to the DVB Program? Thanks! | |||
| cas, programmer |
