skystar hd2 setup?
Old 28-02-2009   #1
My System: dvb s2 usb for pc
skystar hd2 setup?
hi friends,
I am very new to dvb s, just installed pci dvb s2 card "technisat skystar hd2".
facing some problems given beneath.
1. installed software dvbviewer pro, but no channel scan is working. probably hardware not initializing.
2. i have then tried dvbdream but showing me error of hardware initialize error code 12.
currently I am trying to scan transponder and channel of insat 3c http://www.lyngsat.com/in3c.html
my hardware setup is
system: xp sp3, amd 3200+ 1gb ram.
sat hardware: dvb s2 pci card "technisat skystar hd2", ku band dish 60cm, lnb supports dvb s2, no DisEqc, direct cable from lnb to my pc card.
my location: 21n 72e, western part of india.
krishn is offline   Reply With Quote
Old 28-02-2009   #2
Archived Member
Originally Posted by krishn View Post
hi friends,
currently I am trying to scan transponder and channel of insat 3c _http://www.lyngsat.com/in3c.html
Are you sure that you are pointing to the satellite?
Is dish size 60cm large enough for this satellite in your location?
Have you tried using standard receiver to scan the channels with success?
HB13DISH is offline   Reply With Quote
Old 28-02-2009   #3
i am 100% sure because I have just pulled out cable from my existing dth provider which you can find here h**p://www.lyngsat.com/in4cr.html and insert in to my new pci card.
Old 28-02-2009   #4
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
In DVBViewer Pro, go to Options - Hardware and rescan the Mantis driver.
DVBDream has known problems with some BDA drivers, try this one -
Llew is online now   Reply With Quote
Old 28-02-2009   #5
ok installed new driver now but no success.
Old 28-02-2009   #6
any good guide from which I can confirm that my card is working properly and getting signal?
Old 28-02-2009   #7
Sotos65's Avatar
My System: Receivers: Edision Argus, Technomate TM-5300D+ USB, Skystar HD2 Dish: Tecatel 1.10X1.20 LNB: Sharp BS1REL100W Sat motor: Moteck SG2100 PC: Cpu C2D E8400, 2GB.
DVBDream+Skystar HD2 will only work with a customed device file, called "BDA_ALL". There are two files, BDA_ALL.DEV and BDA_ALL.INI, you must put them in the "Devices" folder located in the root folder of your DVBDream installation.
BDA_ALL.zip
As far as I can see the channels you are trying to receive could be the ones from the "Airtel" package, transmitted exclusively in DVB-S2. So in order to receive them with DVBViewer Pro you must go to Settings>Options>Hardware and make sure that the "Is DVB-S2 device" check button is selected. And finally you should check if your transponders .ini files are up to date.
Skystar HD2 works fine here with the latest drivers and those two programs...
Sotos65 is offline   Reply With Quote
The Following User Says Thank You to Sotos65 For This Useful Post:
nebula (13-03-2009)
Old 13-03-2009   #8
My System: 1.2 M STAAB motorised C120 Invacom 0.3db uni LNB with feedhorn Triple dragon reciever Qualit-Tv SatLook Digital NIT Diablo light CAM, CAS2+ Aston crypt with digital + card Sly mindish and subscription.
wow thanks alot Sotos65 for the helpful advice! my SS2 HD2 is working lovely now! Thankyou!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
nebula is offline   Reply With Quote
The Following User Says Thank You to nebula For This Useful Post:
Sotos65 (16-03-2009)
hd2, setup, skystar
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
