Mediaguard2(seca2) and Videoguard possible?
Old 02-03-2009   #1
My System: Sat TV : Astrx (ku band); Satellite : Mexsxt 3 PC: AMD Am2 4000+ 2GB ddr2 ram Winxp Sp2 MediaCenter 2005; DVB-S card: haven't decided
Hi, i'm newbie on sat tv and i need some guidance.
I'm a payed subscriber of my local sat tv, therfore i have the smartcard.
According lyngsat.com, it uses Mediaguard2 and Videoguard.
I'd like to record sat tv onto my home-theater pc using progdvb. I've done some reading, and it tells me i need a compatible dvb-s pci card, and some "softcam", 'cause there's no CAM for seca2.
Is it possible to do this? If so, how would i go about setting it up?
Please help out, thanks !!
newsatuser is offline   Reply With Quote
Old 03-03-2009   #2
Anyone can help?
Old 03-03-2009   #3
Amo Amas Amant Admin
Topper's Avatar
Well
Originally Posted by newsatuser View Post
Anyone can help?
Perhaps if people knew what your local TV was they would be able to answer you. A location of Malxysixm in your profile means nothing to me, what satellite is it? what bouquet is it?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Topper is online now   Reply With Quote
Old 03-03-2009   #4
Site administrator
Analoguesat's Avatar
Lets see - the IP address resolves to Malaysia so nsu is probably after the Astro TV package on Measat 3.
Analogue forever!
Old 03-03-2009   #5
Archived Member
There are DVB-S PCI cards with a CI slot.
All you need to do is buy a compatible Seca 2 CAM and insert the smartcard inside the CAM.
Check out our site sponsors for such a CAM.
But check first if the smartcard should be matched/married to the STB.
HB13DISH is offline   Reply With Quote
Old 04-03-2009   #6
Thanks for all the replies!
This is the part were i'm clueless, and there arent many newbie/beginner tutorials around. I'll be glad if you could recommend some good tutorials.
I've found some mediaguard2 CAM on your sponsor's site, but there aren't any CAM with both mediaguard2 and videoguard.
If i happen to find a mediaguard2+videoguard cam, will it work for all sats? or does it only work for a particular sat?
Do mediaguard2 and videoguard softcams even exist?
Is important that my smartcard matches/married the STB?
I don't quite understand.
I already have my smartcard + stb supplied by my sat tv, and i'm not looking for a new stb, just a pci dvb-s and a way to connect my sat dish to my hometheater-pc.
Old 04-03-2009   #7
Archived Member
It would help if you can tell us the package name and if your card is videoguard or mediaguard2.
Old 05-03-2009   #8
This one: [U]_http://www.lyngsat.com/packages/astromalaysia.html
Not sure if my card is videoguard or mediaguard2, or both.
Old 06-03-2009   #9
Archived Member
This one: [u]_http://www.lyngsat.com/packages/astromalaysia.html
Take a good look at the card, from both sides and see if there is any info regarding the encryption system. It can't be both. Or ask the provider.
Anyway, you will be taking a big chance if it is in Videoguard (NDS).
My recommendation is to save your money on buying PCI card and CAM and just use the analogue AV output from your receiver and a video card with AV inputs and a software application like Nero to record to the PC.
Old 11-03-2009   #10
Sorry for the late reply. As you can tell i'm elsewhere.
There only info on my smartcard is the barcode and some numbers. No mention of any encryption system.
I thought it uses both mediaguard2 and videoguard 'cause thats whats mentioned on lyngsat.com.
However I've asked around and foundout that Dreambox DM600PVR is indeed compatible with my local sat tv's smartcard. Does this info give any hint on what encryption my sat tv uses?
I'm yet give up my first preference since i already have a htpc sitting around. Looking forward for all your ideas and suggestions.
Thanks!!
Old 12-03-2009   #11
Topper's Avatar
What is written on the card there must be some writing? if it is just plain white then it cannot be a genuine subscription card.
Why not take a snapshot of it them we can see it!
You have still not confirmed what the package is....what is it????
If you don't answer the questions asked it will not be possible to help
Show Your Support
Thank you.
Old 12-03-2009   #12
Archived Member
The package is Astro Malaysia, according to post #8
Old 13-03-2009   #13
Originally Posted by Topper View Post
What is written on the card there must be some writing? if it is just plain white then it cannot be a genuine subscription card ...
The link to the package is at post #8.
Nothing, just the corporate logo in the front, and the barcode at the back.
I quite certain the bills i receive every month is pretty genuine.
Looking forward for all your replies.
Old 13-03-2009   #14
Topper's Avatar
Well
I am still unclear as what the question is, if you have a subscription card, I suggest getting the DMR600PVR if you are certain it is compatible, not many people in Europe will know much technically about a satellite on the other side of the earth to us i.e. below our horizon. However please be aware that it is entirely feasible that whenever you want to watch the recording you will probably need to decrypt it again with your smartcard.
Show Your Support
Thank you.
mediaguard2seca2, videoguard
