Difficulty in opening port for GboxDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 28-05-2007 Location: Terre Rouge, Mauritius
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst |
I wanted to see how gbox works on SS2 PCI. But i'm stuck with UDP port forwarding. I've forwarded port for utorrent(TCP) and it works. I forward port 2077 UDP in my router Sagem Livebox 43b5 and put exceptions in my firewall(both windows and Kaspersky)but no udp seems to work. When I enable any TCP port it does work. Please help what could be the problem. I run a small prog TCPvieWer.My pc is set to a static ip 192.168.1.43 and I'm thru dyndns host. Here is what it's look svchost.exe:900 UDP user-28bc844c4e:1900 *:* wltuser.exe:4752 UDP user-28bc844c4e:3219 *:* WINWORD.EXE:5476 UDP user-28bc844c4e:3126 *:* svchost.exe:476 UDP user-28bc844c4e:1048 *:* lsass.exe:1796 UDP user-28bc844c4e:isakmp *:* OUTLOOK.EXE:4948 UDP user-28bc844c4e:3111 *:* svchost.exe:476 UDP user-28bc844c4e:1047 *:* System:4 UDP user-28bc844c4e:netbios-ns *:* svchost.exe:900 UDP user-28bc844c4e:1900 *:* svchost.exe:476 UDP user-28bc844c4e:bootps *:* svchost.exe:476 UDP user-28bc844c4e:1100 *:* svchost.exe:476 UDP user-28bc844c4e:ntp *:* mDNSResponder.exe:2008 UDP user-28bc844c4e:1025 *:* System:4 UDP user-28bc844c4e:netbios-dgm *:* System:4 UDP user-28bc844c4e:netbios-ns *:* KService.exe:720 UDP user-28bc844c4e:1948 *:* svchost.exe:476 UDP user-28bc844c4e:ntp *:* mDNSResponder.exe:2008 UDP user-28bc844c4e:5353 *:* svchost.exe:476 UDP user-28bc844c4e:bootpc *:* mDNSResponder.exe:2008 UDP user-28bc844c4e:51224 *:* System:4 UDP user-28bc844c4e:netbios-dgm *:* svchost.exe:900 UDP user-28bc844c4e:1900 *:* svchost.exe:476 UDP user-28bc844c4e:domain *:* lsass.exe:1796 UDP user-28bc844c4e:4500 *:* svchost.exe:476 UDP user-28bc844c4e:ntp *:* System:4 UDP user-28bc844c4e:microsoft-ds *:* iexplore.exe:268 UDP user-28bc844c4e:2358 *:* mDNSResponder.exe:2008 UDP user-28bc844c4e:5353 *:* jqs.exe:240 TCP user-28bc844c4e:5152 localhost:3503 CLOSE_WAIT iTunesHelper.exe:956 TCP user-28bc844c4e:1039 localhost:27015 ESTABLISHED KService.exe:720 TCP user-28bc844c4e:1035 localhost:1036 ESTABLISHED KService.exe:720 TCP user-28bc844c4e:1036 localhost:1035 ESTABLISHED KService.exe:720 TCP user-28bc844c4e:1037 localhost:1038 ESTABLISHED KService.exe:720 TCP user-28bc844c4e:1038 localhost:1037 ESTABLISHED PCSuite.exe:296 TCP user-28bc844c4e:1058 localhost:1110 CLOSE_WAIT mDNSResponder.exe:2008 TCP user-28bc844c4e:5354 user-28bc844c4e:0 LISTENING System:4 TCP user-28bc844c4e:netbios-ssn user-28bc844c4e:0 LISTENING System:4 TCP user-28bc844c4e:microsoft-ds user-28bc844c4e:0 LISTENING AppleMobileDeviceService.exe:1924 TCP user-28bc844c4e:27015 user-28bc844c4e:0 LISTENING For UDP i see only *.* for remote address. Any help is welcome. I'm now doubting whether it is not blocked at the ISP level. | ||
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst | It was my Livebox Firewall(parefeu). in Advanced config I had to disable it. So it works now. | ||
| difficulty, gbox, opening, port |
