Converting incoming Sat signal to IP then streaming... | |
| Member Join Date: 24-03-2009 Location: Europe
My System: lots |
Ok so i have been working on this for a while and now have decided i need more brain power! I am looking to 'catching' the signal directly from the LNB or switch in signal format, not video. Then converting this to a stream to stream over the net and then catch it and convert back! Many people will come back and say ahh use the Slingbox, its great! yes i agree but this simply sends the video not the signal - so does not solve the concept. In practice it will work like this - Dish set up in the Uk receiving - for arguments sake - Sky. Signal is 'caught' sent over the internet to a in IP format, this is then somehow converted back to the original signal via a gizmo and then a cable from the gizmo to a sky receiver. The concept is aimed to deliver satellite signal to places where you cannot fit dishes but have a good internet connection, for example high rise flats. i have simply used Sky as an example, it is the signal i am concerned about not the Tv content. Hopefully this makes some sense and is not the ramblings of a mad IT installer!!!! Any ideas!? Cheers | ||
| Specialist Contributor Join Date: 28-11-2004 Location: Lanzarote, Canary Islands
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3 | Welcome to the Forum. I can see advantages of what you are trying to do. Especially as the signal would still be encrypted where applicable as you stream it so I would have thought there would be no problems with uncle Rupert´s Lawyers. Even if you get no joy on this forum keep us informed how you get on. Good luck | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The bandwidth required for such a system would be immense, in the region of 1Ghz for just one H/L V/H combination. It can be done by a direct fibre optic link, but via the internet, I don't think so. Even to get a good picture on a Slingbox is difficult enough practically, let alone a whole IF. | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | Welcome villait, Nice idea, and the makings of an interesting thread. (putting my nerdy glasses on) I'm sure it will become a possibility in the not so distant future (if it doesn't already exist). One of the main problems would be with upstream data rates. A sling box or similar will only be uploading the required video and audio data. My understanding is that if you want to upload a raw signal you are talking a lot of data. Any particular frequency an LNB is tuned to will be carrying enough data for multiple video/audio streams so, I would suspect that you would have an ammount of data that even the fastest internet connections (in this part of the world) would struggle to download quickly enough, let alone to think of uploading it. I'm no sat signal expert, so if one of the more knowledgeable sat signal experts chimed in with some figures on data rates available on a sample transponder, that would be great. The other thing would be that you would have to have exclusive access to and LNB, because it can only be tuned to one frequency at any given time. If you were thinking of providing this as a service, you would need to have an LNB per frequency, per satellite along with servers and client side software to handle it all. As trigger said. Let us know how you get on if you dont find a solution here. PS: My comments are only to highlight the technical problems to see if anyone can think of a way around them, not to say its impossible. C ![]() EDIT: ![]() Robbo got in ahead of me with the main problem. I should not wander off to make a cup of tea while posting. | ||
| | #5 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | hm... why need to stream all bandwidth at same time? targeting multi-tv audience? | ||
| | #6 | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| You probably should look into the technology of IPTV or TV over IP and how this is done. In your example you typed: and then a cable from the gizmo to a sky receiver Surely you would need another type of receiver, certainly not a satellite receiver. | ||
| | #7 | |||
| Member Join Date: 18-03-2008 Location: Bangalore - INDIA
My System: 14 Feet C-Band Mesh Dish and TECHNOSAT CX - Digital Satellite Receiver. | You may visit their site to check it out: __http://www.viewcast.com/product_niagaraPro2.asp | |||
| | #8 | ||
| Member Join Date: 04-01-2008 Location: India
My System: 6 Feet C band in Insat 2E 8 Feet C band in Asiasat 75 cm Ku in Insat 4B Kaon Receiver Pentium 4 1.7 GHz | It's a good idea. But only if we can afford this much bandwidth. It's leagal and can be saw any channel that's not available in our region. And can be use CS for encrypted channels. | ||
| converting, incoming, sat, signal, streaming |
