Problems with HD DVB-S2 and OSD in DVBViewerDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 05-04-2009 Location: Poland
My System: 80cm antenna, two LNB with DiseqC (astra + hotbird). Skystar S2 + DVBViewer on P4 2,6GHz, 1GB RAM, HD2600XT on AGP. |
Hi, i have few problems with dvbviewer. I don't get any replies on official board ![]() I'm using the newest version of DVBV downloaded from members section + ArcSoft codecs (and Powerdvd 9 codecs for test) and EVR. This works with Skystar S2 on the newest BDA driver. Running on Vista Home premium with all new updates. My PC conf is: P4 2,6GHz, 1GB RAM, HD2600XT on AGP. My biggest problem: On FTA HD DVB-S(2) channels from Astra, all is good. But on hotbird only HD DVB-S FTA is ok. HD DVB-S2 is no video and audio, but signal is still ok. (beetwen 78-80% and on astra is similar) Sometimes, for approximatelly 500ms i hear sound. I'm using also local sharing in my home (it's legal in my country) and DW on HD DVB-S2 channels also go ok, but picture is black ![]() Second, but smaller problem: Sometimes OSD isn't started. If i change channel i don't see nether panel. If i click Esc also don't start menu and not working volume changer in scroll. I must restart app. Third problem: I have a two satellites config (astra + hotbird). If i open program on hotbird and next go to astra channels, DVBV view a 15% of quality signal and not view a channel. If i close program on astra, on next open all is ok. (go from astra to hb is ok, but if again go to astra i have the same problem). | ||
| Member Join Date: 15-03-2009 Location: Russia
My System: homson DSI-4000NTV,Openbox-800,TeVii-S460,DRS-4500 u.a. 13,36,56,75,80,90,96.5,105.5,115/125,5. Intel Core2 Quad CPU Q8600 @2.4 Ghz 2.41Ghz,2.00 Gb | It is a processor problem or codec problem, in dvbviewer. Look processor loading.Ctrl+Alt+Del. In HD2600XT hardware acceleration works. | ||
| The Following User Says Thank You to kwp58 For This Useful Post: | Przemek211 (13-04-2009) |
My System: 80cm antenna, two LNB with DiseqC (astra + hotbird). Skystar S2 + DVBViewer on P4 2,6GHz, 1GB RAM, HD2600XT on AGP. | yes, if i'm using dxva (arcsoft or powerdvd codec) channels from astra assume approximately 30% from my CPU. Without this function (coreavc - 100% and picture jumping). On HD channels from HB which not working processor consuming about 5-20%. Thanks for your reply and if you have any other idea please write here | ||
| | #4 | |||
![]() I can send by mail dvbdreamsetup v14i+codecsfordvbmagic [10 Mb].The best program. _http://www.filestube.com/67b86a9be96c07ec03ea/go.html | |||
| The Following User Says Thank You to kwp58 For This Useful Post: | Przemek211 (14-04-2009) |
| | #5 | ||
My System: 80cm antenna, two LNB with DiseqC (astra + hotbird). Skystar S2 + DVBViewer on P4 2,6GHz, 1GB RAM, HD2600XT on AGP. | Ok, but i buyed graphic card specially with DxVA for HD films and HD television. When i'm using with this function - on M2 HD I have also 30-35%, sometimes less. | ||
| dvbs2, dvbviewer, osd, problems |
