Live football on saturday please... | |
| Regular Member Join Date: 27-03-2009 Location: United Kingdom
My System: Skystar HD PCI Card CAM Interface Technomate TM-2300 Super 85cm Dish 0.1 lnb Dreambox DM500s Clone AMD Athlon 3200+ cpu Asus A7N8X-E Delux Mobo 2 x 500GB Hard Drives nVidia 7300 Graphics card 2Gb ram Windows XP Pro 24" HD Widescreen LCD Mo |
I would like to know how i can use dvbviewer to watch live football on saturdays, i have been looking around on the tinternet for a while, but i do not really understand what i have to do...i have also looked on you tube to see if any tutorials are available but nothing is there. I intend to buy a cam when money is available, but until then i am looking to see if there is another way i can start watching footy. The whole plugin process is a minefield, and i do not understand one from the other...i really hope someone has time to help me ( and probably dozens more ) Once again, many thanks.... | ||
My System: Skystar HD PCI Card CAM Interface Technomate TM-2300 Super 85cm Dish 0.1 lnb Dreambox DM500s Clone AMD Athlon 3200+ cpu Asus A7N8X-E Delux Mobo 2 x 500GB Hard Drives nVidia 7300 Graphics card 2Gb ram Windows XP Pro 24" HD Widescreen LCD Mo | it's ok. I have managed to find the information off another forum. | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | you just need to point the vplug installer to the plugins folder of your dvbviewer install and away you go to see the matches on nova sport 1west and of course add the latest vkeys file to the plugin folder. | ||
My System: Skystar HD PCI Card CAM Interface Technomate TM-2300 Super 85cm Dish 0.1 lnb Dreambox DM500s Clone AMD Athlon 3200+ cpu Asus A7N8X-E Delux Mobo 2 x 500GB Hard Drives nVidia 7300 Graphics card 2Gb ram Windows XP Pro 24" HD Widescreen LCD Mo | Thank you for a reply, however..is there any way i can check to see if its working ok ?? I do not see any difference, but thousands of channels to go through is a minefied !! Also, are there any othe pieces of software i can use to open channels ?? | ||
| football, live, saturday |
