SkyStar HD 2 Specs | |
| Regular Member Join Date: 07-11-2005 Location: Glasgow
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR |
Does anyone have detailed specs for the SkyStar HD 2 PCI card ? Details on the Technisat site are a bit sparse. In particular I would like to know what the symbol rate range is. Also, I assume it is a DVB-S2 compatible card ? Edit: - After googling it appears that the symbol rate range is 2-45Mbps. Pity, was hoping for 1-45Mbps. | ||
| Last edited by Ratchet; 10-04-2009 at 03:48 PM. Reason: Found anwer on Google | |||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
Try again in the download section. | |||
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | I have checked the PDF manuals available in the download section if that's what you mean and found no mention of the symbol rate capabilities. If you mean somewhere else within the download section then please point me in the right direction. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Ratchet, it's a rebadged Twinhan AD-SP400, the specification of which can be found here - _www.twinhan.com/product_AD-SP400-2.asp Llew | ||
| The Following 2 Users Say Thank You to Llew For This Useful Post: | Artur_meia (27-06-2009), Ratchet (10-04-2009) |
| | #5 | ||
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | Thanks Llew, just the type of info I was looking for. | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Not too impressed with it for scanning low symbol rates, mine's fairly deaf to anything under ~2250 Mbps. Perhap's it's just my card though ![]() Llew | ||
| | #7 | |||
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | I've had symbol rate issues in the past and cured it by replacing my Invacom quad LNB. The old one worked fine apart from the low symbol rates. No problems with the new LNB. | |||
| | #8 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I don't have any problem with those low rates when I scan the same channels into, say, my Echostar or Fortec Passion HD. Tried different DVB applications on the PC, same problem. My older Skystar 2 with a different tuner/driver is better than the HD version. I swopped an Invacom dual with a new quad, but there was no difference. Hope your quest for a PCI card with the specs you want is successful, I'll keep a lookout too. Llew | ||
| | #9 | ||
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | Cheers Llew, I decided just to go for a Nova HD S2. I've went for a different solution for recording encrypted HD channels - a Hauppage HD PVR linked to my Passion HD/Diablo. This has the added benifit of being able to record output from my PS3 also. | ||
| | #10 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Phew, that Hauppauge is some bit of kit ![]() Should work great with the Passion. Let us know how you get on with the low SR's on the Nova. Llew | ||
| | #11 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | I'm after a hd satellite card for my pc to view hd feeds etc i take it the skystar hd is not good for this ? what the best one to buy ? | ||
| | #12 | |||
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | 36.0E Mir Belogorya - 12546 V 1747 3/4 TBM - 12616 V 1628 2/3 TelefortuneSat - 12633 V 1331 3/4 33.0E Hayat TV - 11093 H 1429 5/6 Gercek TV - 11096 H 1526 3/4 Rete Oro - 11164 V 1666 2/3 12.5W Calabria Channel - 12604 H 1481 3/4 22.0W Sardegna Uno - 11636 H 1695 5/6 24.5W One TV - 11025 V 1475 7/8 My only gripe so far is that it takes a while to initialize when I launch DVB Viewer and can be sluggish sometimes when switching between channels. * * Edit - ignore my original gripe about speed, worked fine after a reboot | |||
| | #13 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Llew | |||
| | #14 | |||
Llew | |||
| | #15 | |||
Llew | |||
| | #16 | ||
| Specialist Contributor Join Date: 21-08-2004 Location: Wales
My System: Technomate 1500CI+ and Hauppauge WinTV NOVA-HD-S2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish. | I love my Nova, only problem is the signal read out is useless 94% or nothing. Scanning low SR's and really weak feeds are a breeze. | ||
| The Following User Says Thank You to remlap For This Useful Post: | Llew (16-06-2009) |
| | #17 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Just popped it into the PC. I'll put it through its paces tonight, see if it's compatible with Linux (OpenSuse/Kaffeine). Can't find a source in TSReader that works with my tuner version (69100). What source file did you use remlap? Maybe I need to update to a later version. Llew | ||
| | #18 | ||
My System: Technomate 1500CI+ and Hauppauge WinTV NOVA-HD-S2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish. | I am fan of DVBViewer and its Transedit to be honest, it does all I need include monitor transport streams. | ||
| | #19 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Yes that's what I invariably use. Just wanted to confirm that the Nova picks up TSReader. Got it to work, but very flaky, only manages to tune a few TP's on various satellites. Just trying it out on Linux. Finds the driver, but Kaffeine doesn't show a DVB tag. Need to find some firmware that will work with it. Llew | ||
| | #20 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | SR is 2-45mbps for DVB-S but 10-30mbps for DVB-S2 please take notice. | ||
| skystar, specs |
