which is best dvb-s2 card ?
Old 16-04-2009   #1
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
i have a skystar 2 card in my pc which i use to watch 4:2:2 feeds on but want to upgrade to a hd compatible card
can anyone recommend a good card ?
i have looked at the technotrend s2 3200 and the nova hd s2 but not sure which card overall is best as i was going to get the skystar hd but read a few comments in this section and not sure about that one.
i have also come across the prof dvb s2 7300 card, has anyone got this one ?
spec is on _http://www.prof-tuners.com/eng/prof7300.html
thanks
wod
Old 16-04-2009   #2
starman345's Avatar
My System: 10' c/ku dish with VonWeise, Gbox 3000, 90cm offset, SG-2100, Dvbworld 2104 USB, Dvbworld 2004 PCI, Twinhan 1020A, BLSA BroadLogic PCI, TBS 8920 PCI
Any of the cards will do HD, I have the Dvbworld cards (in my signature) and they work nicely. I have a TBS 8920 on order, I've heard good things about them but we will see once I get it. What software are you planning to use with the card. Not all cards have drivers that allow all the features with all the different dvb applications.
starman345 is offline   Reply With Quote
Old 17-04-2009   #3
wod
wod's Avatar
i will be using either altdvb, dvbviewer or dvbdream and also smartdvb looks a nice little bit of software.
i'm mainly wanting it for the dvb-s2 4:2:2 feeds i've heard about as the tennis one on 10east is in this format i've been told.
Old 17-04-2009   #4
starman345's Avatar
I can only tell you my experience with my cards, hopefully someone else will add their experience with other cards.
The Dvbworld 2004PCI dvb-s2 card works with full functionality with Dvbviewer, diSEqC1.2, and switch control. It also works with Dvbdream in that it will tune and play channels but I can't move my dish or switch my DiSEqc Spaun 411F switch. The Dvbworld 2104 USB dvb-s2 card will tune and play channels with Dvbviewer and can move the dish and switch the switch as well. It is fully functional with Dvbdream, will move the dish and switch the switch. Both of these cards have full functionallity with the latest MyTheatre 4.0 beta.
I haven't had much luck with either of these cards and Altdvb and I've never tried SmartDvb so can't comment on that.
Not sure if you are aware but not all codecs will display 4:2:2 signals. You will need Elecard, Dscaler, or FFdshow, there are probably a few others but those will work for sure.
I've had quite a few cards over the years and I find the Dvbworld cards compare very well and have very nice sensitive tuners in them, I think both the above mentioned cards have the same tuner. The drawback is that they are very hard to find, you can buy them direct from Dvbworld in China.
The Following User Says Thank You to starman345 For This Useful Post:
maxtor (04-06-2009)
Old 18-04-2009   #5
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR
Wod, just tuned into the Monte Carlo feed on 10.0E with my Nova HD S2. I can confirm that this card handles the 4:2:2 feed OK as long as you use a compatible codec (MainConcept for me). One thing to note though is that although the feed is in DVB-S2 / 4:2:2 it is not HD. The resolution looks to be 576i but has a very good bit rate of 11.7Mb/s. I have included a couple of screen caps.
Ratchet is offline   Reply With Quote
Old 18-04-2009   #6
Archived Member
I personally prefer DVB-S2 cards which have the possibility of adding a CAM accessory, so that an official subscription card will also work on the PC.
SkyStar HD2 is one such option, but surprisingly enough Hauppauge doesn't have such option.
HB13DISH is offline   Reply With Quote
Old 18-04-2009   #7
wod
wod's Avatar
excellent where did you buy the card and also is that mainconcept codec included in the software ?
Old 18-04-2009   #8
I got mine from ,Amazon for £69.99 with free delivery (2 days). The software package that comes with it is Cyberlink Power Cinema which uses Cyberlink codecs. To be honest it's not very good and the codec doesn't handle 4:2:2. Personally I use DVB Viewer and Transedit for tweaking transponder ini files. I think I got the Main Concept stuff from a 'HD Codec' pack I found on one of the many DVB support sites out there.
Old 19-04-2009   #9
My System: Gibertini 125cm, SMART Titanium 0,2 LNB, motorized, Manhattan Plaza, Vantage 8000 HD, SkyStar HD2 and Hauppauge HVR-4000 card
Hi Wod,
I've just ordered a Prof Red Series DVB-S2 7300, when it arrives, I'll let you know about my experience.
At the moment I'm usig a SkyStar HD2 card and also a Hauppauge HVR-4000 card. Both of them works well for DVB-S2 4:2:2 feeds, and also for DVB-S2 HD channels. For 4:2:2 I'm using DVBViewer with bitcontrol codec.
Regards,
Balazs
benko5009 is offline   Reply With Quote
Old 19-04-2009   #10
wod
wod's Avatar
benko5009, thanks for your reply. the spec on the prof card looks good as it uses a Conexant broadcast decoder chip on it, dont know if these are better than whats on the other hd satellite cards
are the dvb-s2 feeds really in 4:2:2 as i've only heard this mentioned on satelliweb feed site
Old 19-04-2009   #11
Yes, in most of the cases they are in 4:2:2.
For example, today ATP Masters from Monte-Carlo was dvb-s2 4:2:2.
Regards,
Balazs
Old 19-04-2009   #12
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
I had that down as MPEG2 4:2:2, as I watched it on my Skystar2 (DVB-S only).
Llew is offline   Reply With Quote
Old 01-06-2009   #13
My System: Thermaltake Mozart VX / XP MCE 2005 / E5300 / 2GB / ATI 4550 HD / TT 3200 / 4W / 7W / 13E / 16E
Dear starman,
just saw you ordered TBS 8920. I am right before ordering one for myself and wandering are you happy with it ?
did you encountered problems with the popular DVB software ? (progdvb, dvbdream, dvbviewer, plug-ins ?)
will be happy to hear your recommendation
eranshl is offline   Reply With Quote
Old 08-06-2009   #14
Real name: ammar
My System: I like Skystar2
Dear Starman,
since you own The Dvbworld 2104 USB dvb-s2 card ,, did you try it with capturing internet traffic using Skynet or Skygraber ,,, I want to buy one ,, but I need it to do just that task ,, random capturing of internet contents by other users on Europe-online and openSky at Eutelsat w3.....
I appreciate your comments.......
maxtor is offline   Reply With Quote
Old 02-08-2009   #15
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
SkyStar HD2 is not rocket fast performer when things come to low symbol rates.
BombedOne is offline   Reply With Quote
Old 02-08-2009   #16
Llew's Avatar
Much better for low SR's is the WinTV Nova HD. ZIF tuner chips are not known for great performance with low SR's, but at least the Conexant chip in the Nova is fully screened, unlike the Skystar's.
I notice the new Skystar S2 PCI has a 'tin box' type tuner, does anybody know which tuner chip is used in this one?
Old 02-08-2009   #17
BombedOne's Avatar
Was not SkyStar S2 released BEFORE the SkyStar HD2 ?
Old 02-08-2009   #18
Llew's Avatar
They did a DVB-S2 card a couple of years ago before the HD2, called the Skystar HD, somewhat larger in profile. This one comes after the HD2.
card, dvbs2
