Skystar 1 & 2 | |
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 |
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | |||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| One feature that springs to mind is that it has a TV Out connector, and if I am not mistaken, a possibility to add a CI CAM. But it is an old card and there is no support for it. Personally I wouldn't touch it. | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I believe there were two versions of the Skystar 1, one with an outboard CAM module, and one with the module incorporated. Also they have hardware decoding, easier on your CPU. As HB says, not much support now, although I think the later version of DVB Viewer will work with it. Llew | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | There are two skystars 1 - One with CI module is nothing just rebranded TwinHan VP1031, with software mpeg decode and so on. Original SkyStar 1 has hardware mpeg2 decoder (only actual if you have pentium 2/3) and tv out. Original SkyStar1 is limited in Symbol rate (range is 8000-30000 afaik), while Skystar2 can handle 1000-45000. | ||
| | #5 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Ah, just the original one with hardware decoding. Sorry. | ||
| skystar |
