Cards for feed hunting :)Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 25-04-2009 Location: West of Scotland
My System: SkyStar2 2.6 PCI - 90cm old Sky dish w/Universal LNB - and more "recycled" dishes (there are 5 on my roof .. not being used !) | Hi, I read a few of the articles and I can understand that Hauppages and SkyStar cards seem to be the best. However I am curious if someone has knows of cheap/simpler cards which are compatible with the linux modules (to use dvb* tools). I am only interested on the technical side of it and I don't really care having a good quality feed displayed (I.e. HD). However I wouldn't like to be limited by the card on decoding and other hw features. I have seen on Ebay P.S.= I am just starting and I want to keep a VERY low budget as I have already wasted money on so many hobbies which I didn't eventually pursue, so I am aware that eventually there will be a "minimum" of equipment quality required. At present I am only interested in a "taster". THANK YOU ! | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Hi, welcome to the forum. Best to check over at _www.linuxtv.org/wiki/index.php/DVB-S_PCI_Cards for cards with drivers supported in Linux. Skystar 2 Rev 2.6 and earlier OK. Don't get Rev 2.7 as I found it doesn't work, although some development is in progress. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | nikione (25-04-2009) |
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | SkyStar 2 rev 2.3 is the best one, since it has auto SR feature, and also software exists for blind scan (don't know any other pc card capable of blind scan). | ||
| The Following User Says Thank You to BombedOne For This Useful Post: | nikione (25-04-2009) |
My System: SkyStar2 2.6 PCI - 90cm old Sky dish w/Universal LNB - and more "recycled" dishes (there are 5 on my roof .. not being used !) | Thanks a lot guys ! That's exactly the info I was looking for. The blind scan is a particularly important aspect, especially if I get more handy and I get a motorised dish. I had already a look at that website, however I was hoping there was some more resources around, maybe showing all the cards name and their chipset (might be that some of the cheap ones have the same chipset as skystar ??). Finally, any thoughts on Hauppage cards (WinTV Nova/Nexus) or VideoMate ? Thanks again !! | ||
| | #5 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | | ||
| | #6 | ||
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | Just my two cents.. I'd never ever get one of those el-cheapo Hong Kong £20 cards from fleabay. Too many things could potentially not be up to scratch with them. | ||
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | |||
| The Following User Says Thank You to dvmedia For This Useful Post: | nikione (26-04-2009) |
| | #7 | ||
My System: SkyStar2 2.6 PCI - 90cm old Sky dish w/Universal LNB - and more "recycled" dishes (there are 5 on my roof .. not being used !) | Hence I really hope that a card such as this: Technisat Skystar 2 rev. 2.6b Is one of the "good" ones. | ||
| | #8 | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | | ||
| | #9 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | I have modified several SkyStar 2.3i -s: 1. BSS138 problem removed. (stronger FET fitted) 2. Overheating problem fixed. (fan with bracket) 3. LNB load capacity increased to 1A (new voltage formation circuitry installed) Now I'm thinking, maybe I start commercial offering of such modded cards? Price I'm planning is around US$100... any ideas? | ||
| | #10 | ||
My System: SkyStar2 2.6 PCI - 90cm old Sky dish w/Universal LNB - and more "recycled" dishes (there are 5 on my roof .. not being used !) | Too late. Tomorrow morning I'm receiving the newly bought SkyStar 2 v2.6b Paid it 28£ .. hope it's not too much. It's ok if it has some limitations, as I'm a newbie I don't think I'm gonna be doing too many things right now. Also because I still have only 2 dishes with univeral LNB available ("sky type dish" .. but one is 96cm) One is to Astra 19E and the other one will be pointed to HotBird 9 (13E ?) Question ... Do you know if the 2.6b is able to do blind scanning ? I tried to read most material on LinuxTV.org but didn't really say. Any good resource, apart from forums, that you know on Feed Hunting techniques and best practices ? Also .. generally speaking do these DVB-S card also pick up analogic satellite transmissions or it requires (I suppose) a separate/different tuner silicon onboard ? Thank you again for your precious help. | ||
| | #11 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The 2.6b won't do blind scanning. The only option would be the tiresome one of entering in popular feed frequencies/SRs/FECs into a transponder file of those satellites most used for feeds. For example, if you are using a Linux distro such as Ubuntu with the Kaffeine player, in its DVB-S folder you can add/modify transponders to include the most-used feeds, which you can find here - _www.satelliweb.com/index.php?section=listingsf Recent feeds can be found here - _www.satelliweb.com/index.php?section=livef Skystar 2 pci cards are DVB only, they don't do analogue. Llew | ||
| | #12 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | There DO EXIST software for 2.6b, to allow blind scanning, but it has two limitations: 1. Only available for windows 2. Requires specific version of drivers It's called BxS transponder finder.... | ||
| | #13 | ||
| Member Join Date: 27-09-2003 Location: New Brunswick Canada
My System: 10' c/ku dish with VonWeise, Gbox 3000, 90cm offset, SG-2100, Dvbworld 2104 USB, Dvbworld 2004 PCI, Twinhan 1020A, BLSA BroadLogic PCI, TBS 8920 PCI | Software blindscan? As far as I know the 2.3 version is the only one with autosymbolrate detect. | ||
| | #14 | ||
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | BXS allows pseudo blind scanning (ie. you list the S/R that you want to scan). | ||
| | #15 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Certainly not true blind scan, as you say. I found it useless for low SR's, as many feeds are. Llew | ||
| | #16 | ||
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Agreed, with a 2.6 you're probably best off with a comprehensive transponder list - with a fast scanning engine (such as Alt DVB under windows). You will also want a 4:2:2 codec (such as Nero, Bitcontrol or elecard). The 2.6 is a decent introduction though and will allow decryption emulation and card sharing if needs be - at a reasonable price. | ||
| | #17 | ||
| Regular Member Join Date: 02-12-2005 Location: str8 frum da wesside innit?
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s... | BxS program is SOFTWARE blind scanner. It was written for the 2.6 card because he didn't have a 2.3 card. It's reeeeeeeaaaaaaallly slow, obvioulsy. The whole point of the blind scanning to find feeds is completely lost. Altxro's program is HARDWARE blind scanner. It only works with the 2.3 card, obviously. Bombed one, your offer is nice, but quite honestly, I don't think anyone will pay your 100 bucks for a good old rev 2.3 card... | ||
| cards, feed, hunting |
