VMC + Technisat + TV Pack
Old 30-04-2009   #1
My System: Technomate 5400 CI+ USB, 105cm Gibertini dish, Smart Titanium LNB (0.2 db); FloppyDTV (2) in HTPC.
I have my new Technisat installed and using DVBViewer, I am able to view programs. I set Vista Media Player up by installing the TV Pack. In VMC setup I can see that the card is getting a signal, but when I try to view channels, I get the "No TV Signal" message.
I know the signal is good as I have verified it on my Technomate STB and with DVBViewer. I had this working this morning and due to some other problems, I decided to do a fresh install of everything. I've applied all the recommended patches and the latest version of the TV Pack.
I'm using 28.2 and just did a scan of all transponders and found no new channels. The cable is direct from the LNB to the card (No Diseqc issues).
Anyone have any idea of where I need to look or experience fixing it? I've been googling all day on this one.
Thanks in advance!
Tim
timhan is offline   Reply With Quote
Old 08-05-2009   #2
tph
tph's Avatar
My System: 3.2 metre with quad LNB for 28E with Pace 2600C1. 2.4 metre movable with Samsung DSR9500 & Dragon CAM.
I seem to be in the same boat. Any ideas anyone??
Thanks TPH
tph is offline   Reply With Quote
Old 31-05-2009   #3
the vista media centre will not talk to a dvb s card directly although it says it is scanning chs ok...you need to google dvblink this sets up a bridge for the media centre and makes vista think it is using a terrestial card..i tried this setup with my skystar2 card works very well..also scambled chs can be decoded on your local set up with acamd worth tying..hope this is what u on abt..
cheers
mastercare is offline   Reply With Quote
pack, technisat, vmc
