How do you view feeds with dvbviewer & Skystar USB 2? | |
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 |
dvbviewer is installed and setup, and running tickety-boo on normal channels. I've installed the DScaler 5 codecs. I've gone into dvbviewer - done a channel scan on the frequencies that Lyngsat list as having feeds (I made sure I put in the symbol rates) But it has found nothing.. What am I doing wrong? Thx | ||
| >> BBC Worlds' ultimate fan << >> Satellites are an expensive hobby that run away with you. I am living proof of this... << | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Nothing. They're just not active. When they are, they might only be open for minutes or maybe an hour or two if you're lucky. For currently active ones, check - _www.satelliweb.com/index.php?section=livef Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | dvmedia (01-05-2009) |
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 | Ahh lovely thanks | ||
| dvbviewer, feeds, skystar, usb, view |
