What am i doing wrong? | |
| Member Real name: Giorgios Join Date: 15-05-2009 Location: Sweden
My System: Intel P quad 3.0ghz 4gb ram 1TB sata HD, Asus striker to Xtreme 2, nova HD-S2,vista 64bit,DVBdream,vplug |
After reading for a while this forum i decided to buy a dvb-s2 pci(nova-hd) after installing the progdvb and Vplug, i still can not see any ecrypted channels...i used the latest keys. Is there any scecial settings that i have to do on the plug in? Are the keys different from on to another sattelite? | ||
My System: Intel P quad 3.0ghz 4gb ram 1TB sata HD, Asus striker to Xtreme 2, nova HD-S2,vista 64bit,DVBdream,vplug | Thanx i didnt know that i am on echostar9 right now..what kind of compass do u have when u change the degrees? BTW is there any package for viasat or viaccess? | ||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | | ||
| | #5 | ||
My System: Intel P quad 3.0ghz 4gb ram 1TB sata HD, Asus striker to Xtreme 2, nova HD-S2,vista 64bit,DVBdream,vplug | No i dont have motorised system yet...but the echostar9 i found by luck, but i would like to watch some HD channels and i can not find any | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | You most certainly have not found Echostar 9. It is impossible from Europe, as it is at 121 degrees west and thus way below your horizon. If you want to find 1W, I suggest you try a site like dishpointer.com, it will show you a rough direction to point your dish. | ||
| | #7 | ||
My System: Intel P quad 3.0ghz 4gb ram 1TB sata HD, Asus striker to Xtreme 2, nova HD-S2,vista 64bit,DVBdream,vplug | Well it says on the screen of the progdvb that there is echostar9... do u know any sattelite that there are available hd channels and rechable from Sweden? Here is what is showing... _http://img193.imageshack.us/my.php?image=22152663.jpg Is not possible to unlock the SKY right? | ||
| | #8 | ||
Assuming your longitude is 17 to 18 degrees East (as you do not mention where in Sweden), your visable arc should extend from about 70 East to 35 West perhaps more of course all depends upon line of sight, but check out lyngsat.com to find out what you should be able to pick up | ||
| | #9 | |||
Here is a list from kingofsat of HD channels, most of them are encrypted, but a few are not. _http://en.kingofsat.net/hdtv.php | |||
| | #11 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, there is a stunning difference. On a largish TV for example, I have a 46 inch LCD, the difference is very obvious. SD channels are a bit of a let-down after watching 1080i HD. Its all down to the number of pixels/resolution being used, just like a computer monitor. | ||
| | #12 | ||
My System: Intel P quad 3.0ghz 4gb ram 1TB sata HD, Asus striker to Xtreme 2, nova HD-S2,vista 64bit,DVBdream,vplug | Can i get some help for adjusting my dish with a compass?Any good tips so i get it right? BTW my position is Gothenburg Sweden... thanx guys for all the info | ||
| | #13 | ||
My System: Intel P quad 3.0ghz 4gb ram 1TB sata HD, Asus striker to Xtreme 2, nova HD-S2,vista 64bit,DVBdream,vplug | After trying to adjust my dish to get digitv...my progdvb got issues i think, i have 100% level but no quality, so when i do a scan i can not find any channels and if i use the powercinema it receives channels. Anyone got the same problem b4? | ||
| | #14 | |||
You will be in a box 6 ft under before you manage with a compass........ read the dish installation guides and follow each step religiously. Try to set up a tv in sight of the dish so that you can see the signal levels on the stb. It is not like throwing a snow ball into a lake, you have to be accurate to the millimeter | |||
| wrong |
