how to blind scan in skystar hd2?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 03-01-2009 Location: india
My System: dvb s2 usb for pc |
hi friends, I am using skystar hd2 with dvb viewer pro license version and dvb dream for watching channels. I am looking for the software which can scan all available tps from the pointed satellite. is it possible to blind scan? please tell me if any software of utility available. | ||
| ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ ku dish 65cm , skystar 2 rev 2.3 pci card, dvbviewer pro. location : Gujarat, INDIA. Express AM22 at 53.0°E ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ | |||
| | #2 | |||
| Member Join Date: 27-09-2003 Location: New Brunswick Canada
My System: 10' c/ku dish with VonWeise, Gbox 3000, 90cm offset, SG-2100, Dvbworld 2104 USB, Dvbworld 2004 PCI, Twinhan 1020A, BLSA BroadLogic PCI, TBS 8920 PCI |
| The Following User Says Thank You to starman345 For This Useful Post: | Lancelot (23-05-2009) |
My System: dvb s2 usb for pc | _http://www.dvbviewer.com/griga/TransEdit%20E/MainWindow.html have anybody tried blind scan as given help in link? will it really work? | ||
| ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ ku dish 65cm , skystar 2 rev 2.3 pci card, dvbviewer pro. location : Gujarat, INDIA. Express AM22 at 53.0°E ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++ Last edited by Llew; 25-05-2009 at 03:46 PM. Reason: Killed live link | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | No live links, read the rules krishn. Yes, I do use it occasionally, but as the previous poster said, it is very slow, particularly if your parameter variations exceed a hundred or so - which will be the case if you want to scan a sizeable portion of the tuner range. If using for feeds, best to try just one or two most-used feed SRs at a time to cut down the time taken. 27500 and 22000 SRs on the majority of broadcast satellites will keep you waiting until kingdom come. Llew | ||
| | #5 | ||
My System: dvb s2 usb for pc | yes, I have just tried. it is taking too much time. any pci card available with blind scan inbuilt? or any good fta blind scan receiver? | ||
| blind, hd2, scan, skystar |
