SkyStar HD 2 low DVB-S2 Symbol Rates problem | |
| Member Join Date: 07-06-2007 Location: 75000
My System: aha | Hi. I have SS HD2. Sometime changed drivers, as first installed v1.1 from cd, next new driver 1.2 from Technisat web site, and one time tried others like Technisat Mantis driver BDA_ALL 1.1.0 Scan Man, BDA Native 1.1.0 in DVB DREAM 1.4 h or 1.4i device list, etc. I have problems with for example momentary on 8W 12560 H 3600 DVB-S2. No signal with DVB Viewer, DVB Dream, ALT DVB. Tried to clear pc with Reg Cure, 320 errors found and fixed. But after that no change, again no signal (else signal all the time in this period active on SATELLITE, checked on other receiver). Whats is strange? After that I have maked change in DVB Dream priority from High to Real Time, tried to scan 12560 agan and surprise, signal is there. But, happynness was only some minutes. After restart XP SP2, Reg Cure inform about problems with key and I unstalled him from pc., maked restart again, but after that I havent signal again on 8W 12560 H 3600 DVB-S2. My pc config. is (with installed Microsoft Framework 2.0...maybe 2.0 not good for this car?): Intel Core 2 Duo E8500 3.16GHz 6MB cache, FSB 1333MHz, BOX ECS P43T-A2 (1.0) LGA775, Intel P43/ICH10, FSB1333, 6xSATA2, eSATA, GLAN, 6ch HD Audio Buffalo DDR2-800 2GB PC6400 WD 640GB SATA2 HDD WD6400AAKS, 16mb, 7200rpm ECS nVidia GeForce 9600GT 512MB-MX 256bit, DDR3, Dual DVI, HDTV LG DVD-RW drive black SATA, Bulk 22" AOC 2230Fh display 300 cd/m2, 10000:1,2ms,1680 x 1050,DVI,HDMI,speakers Gigatech GT-409 Codegen Optical Mouse MO-001-CA PS/2, 800dpi MidiTower ATX SK-335 500W, 20+4P, SATA Thanks for any help!!! PS. Momentary feed from 12559 gone and switched to 12554 H, 3600, DVB-S2, signal excellent on other receiver on the same dish but on Skystar NO SIGNAL in this transponder....Else, no problems with low DVB-S SR, only problem with DVB-S2 under 4000 MSymbols/sec....But as I said some minutes ago when I have maked changed in DVB DREAM priority from High to Real Time in the same second signal was there....But after some XP SP 2 restarts and unistalling unregistered Reg Cure signal again gone............Now I have maked some system restore but also lossed some codec like MainConcept H264 and Codec.Check.exe can not add him to Video Decoders......, but thats not problem with pictures, work also with Video (Elecard v20.0221.2003) and Audio (Elecard New v.1.5.340.142), problem is SR 3600 on DVB-S2. Also on ALT DVB its same. And DVB Viewer. Momentary driver on device manager is 1.1.1.302, and on DVB DREAM device list BDA_ALL 1.1.0 Scan Man - Interface 2.0.0 (Technisat Mantis DVBS BDA Receiver (DVB-S), Offset 0). | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Hello. SkyStar HD2 has OFFICIALLY DECLARED DVB-S2 symbol rate of 10-30mbps. Check their SDK for exact specs. People are working on driver patches, but positive result most unlikely to happen - this is hardware restriction. | ||
My System: aha | I have found so often feeds with symbol rates over 6000 MSymbols/sec in DVB-S2, like on 10 E 11070 H 7200 NBA. And also today, and sometime before, 3600 but momentary with problems with this SR. Others working great......because that I can not understand that with 10-30mbps. ![]() ![]() ![]() :co nfused:![]() Specification is untrue, I can watch DVB-S MPEG-4 MAJAN TV with SR ONLY 1085 MS/S (at SDK wrote 2-45000), and DVB-S2 mini package LBC with SR 5000 MS/S, both on 21,6 E. | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Specification gives you guaranteed range - anything outside it MAY BE receivable, but no one can predict what and how. | ||
| dvbs2, low, problem, rates, skystar, symbol |
