Whos nicked my channels
Old 02-07-2009   #1
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap
Got a new lcd tv yesterday so i wanted to watch hd on it via my compro dvbs card , ive got HD2.1 codec pack installed and the corecodec hd 1.9.5
Everything was running fine , untill today when for some reason the hd channels were out , so i did a channel scan and lost quite a few channels including bbc hd , luxe hd.Is this a sat problem, the channels i can get have a signal of 100% and 60% quality which is down a bit from 70% these are 28.5e and eurobirdive reinstalled my card software and driver as well as dvbdream but the same happens, could it be my new graphic card which i installed yesterday ? it did work then , but i updated the drivers for it ge9500gt Any help appreciated
Bugger wrong place, im sure the mods will put in the right place...sorry
portly is offline   Reply With Quote
Old 02-07-2009   #2
Robbo's Avatar
Real name: Mark
Check that you have the correct transponders in your list and that the signal quality is sufficient. Are you getting the SD channels from those two transponders?
Old 03-07-2009   #3
Robbo for some reason, one got the channels back last night after another scan, not sure whats occuringit seems that if i turnoff from the mains my fs4200 box the output seems to be ok to the dvbs card , but if the box is turned on at the mains even in standby it causes a problem now " the dvbs card is connected to the output of the fs4200 box"but this hasnt happened before
Old 03-07-2009   #4
Robbo's Avatar
Real name: Mark
Yes, as you are using the loopthrough from your Fortec star to supply the signal to another receiver you will get this problem
In order for loopthrough to work properly, you need to turn OFF the first receiver, else it will maintain control of the LNB, and won't let the 2nd receiver get a look in.
Some TPs will work;the ones that are on the same band and polarity as the first receiver was on.
Normally, receivers only have to be in standby to relinquish control of the LNB, apart from Sky digiboxes, maybe the Fortec Stars operate similarly to the digiboxes in that respect.
Remember a UNIVERSAL LNB is a switched device controlled by the receiver, the polarity and band needs to be selected.
Old 03-07-2009   #5
Grimm Member
rick1980's Avatar
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500
My fortec Zeta retains the lnb power in standby. I only found out when I blew a diseqc switch 'cause the power was still coming through from the reciever.
I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off!
rick1980 is offline   Reply With Quote
channels, nicked
