SkyStar2 4.5.0Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 20-10-2006 Location: Fylde Coast in West Lancashire
My System: WinXP/Firefox 85cm Transparent dish and 3 dual LNB's 13,19,28 One diseqc to Sky Star 2, and a diseqc to TM1500. Plus a loop from the TM1500 to a Pace MSS100 analog sat receiver. |
I've reinstalled the 1753 version of SS2 with 4.5.0 driver but its not accepted in DVBDream/Option/Device. As I'm useless with PC's, do I need to drag and drop something from the Technisat SS2 Program File into the DVBDream Program File? Or is there a neater method I should be using? | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | I use 4.4.3 - the latest one which still uses "old" method and works fine in Dvbdream. | ||
My System: WinXP/Firefox 85cm Transparent dish and 3 dual LNB's 13,19,28 One diseqc to Sky Star 2, and a diseqc to TM1500. Plus a loop from the TM1500 to a Pace MSS100 analog sat receiver. | V4.5.0 in 1753 works well for me since I first downloaded it. I expect it will still work, if only I can get SS2 back into DVBDream. How do I do that please? | ||
Just for the record I just got my answer trawling thru the DVBDream FAQ and I'm up and running once again. Para 9..... the B2C2 device requires skydll.dll skynet.sys Sky2PCAVSrc.ax | ||
| skystar2 |
