Can't tune 9e on DVBviewer
Old 16-07-2009   #1
My System: WinTV Nova S2 HD No dish yet.
Hi Guys,
First of all I want to thank you for helping me get my system to the state it is now in... hundreds of free channels including bbc hd.
I have a Triax 110 and four lnbs, a diseq 1.0 and a wintv nova s2 card in my pc and have purchased the full version of dvbviewer.
The lnbs are lined up to 28e, 19e, 13e and 9e.
I can't get dvbviewer to see 9e. I have downloaded several channellists but none seem to have 9e on the channel scan dropdown. I can see these channels on wintv7.
I posted these questions on dvbviewer website and got no response!
Thanks for your help.
chew6acca is offline   Reply With Quote
Old 16-07-2009   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
I'm surprised you don't have Eurobird 9 in your list. In DVBViewer's root directory, is there a 0090.ini file in the Transponder folder? If not, you must have a very old list.
If that's the case, unzip and add this .ini file to the transponder folder and see if it appears in your drop down list.
File Type: zip 0090.zip (411 Bytes, 11 views)
Last edited by Llew; 16-07-2009 at 09:38 AM. Reason: Moved to appropriate section.
Llew is online now   Reply With Quote
Old 17-07-2009   #3
Thanks,
I already had a file with that name - but still no Eurobird 9 in the Transponder List. (I do have eurobird 3)
What should I see in the Target Root drop down?
I am also getting other channels in wintv that don't appear in DVBviewer - eg Liverpool fc tv.
Any advice is welcome!
Old 17-07-2009   #4
Llew's Avatar
I think WinTV use a satellites.xml file, different to DVBViewer.
The Target Root is where you add your scanned transponders. Either use an existing satellite name e.g Eurobird 9 (which you don't have at the moment) or write it into the drop-down list. You could then scan in a known Eurobird 9 TP channel using an unused satellite in the transponder list and add it to the root folder's Eurobird 9. No idea if that would work though.
Much better to use the much more versatile Transedit program available from the DVBViewer site, which works in tandem with DVBViewer. You could then check if Eurobird 9 is in its Transponder list.
dvbviewer, tune
