A list of questions.. Want to get a SDVB CardDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| | #26 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Don't have access to my other PC ATM Jason. If nobody replies to your queries, will try to help later. Meanwhile, check the Transedit manual, loads of info in there. Llew | ||
| | #27 | ||
| Member Real name: Jason Join Date: 16-07-2009 Location: South East England
My System: Sky Minidish Sky+ 26" Wide Belinea LCD | I've added that channel list in now.. Recieve all channels I've wanted.. Been clearing up a few that are duplicates etc. Also added ITV HD & have signal, Have the ITV Logo up so thats all Ok! ![]() SD & HD Record & Playback all seems good. Have a few questions (again!) ![]() Is Now and Next the only EPG I can recieve for DVBV? How can I add the BBCi to my channels Also BBC2. How can I pick one video channel from within inside interactive. (I can select the audio feeds using the submenue under ITVi) But each feed shows the quad feed of video. Any suggestions! | ||
| | #28 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I don't have the latest DVBViewer version that allows a Full EPG for SkyUK (which includes BBC, ITV etc.) but from the DVBV forum, here's the necessary details - ------------------------------------------------------------------------------------ The following will allow you to have the full Sky EPG in DVB Viewer (both UK and Italy) To run it you must first install DVB Viewer 4.0 or higher and tick the option to install the NetStream plugin. Make sure you scan for all the channels on your chosen platform. Now in DVB Viewer you need to activate the netstream plugin. So click plugins --> NetStream --> Configure. Choose an IP and port and keep a note of these. Click on stream control. Click Stream Whole transponder. Click back to settings and click Active. Tune to the following Channel for Sky UK EPG Background Audio or IEPG Data 1 for Sky Italia Download the following. OpenEPGtoDVBViewer Version 1.0 Beta (attachment provided - Llew) Ensure you extract both files to any directory. Double click on the OpenEPGtoDVBViewer.exe Under settings, Locate your DVB Viewer directory and insert the IP & Port. Now click apply. Then click the Run Update Now and wait 2 minutes. You will have a fully populated EPG for sky uk You can change the settings to grab whenever (every x amount of hour) you wish, and if the channel isn't available when it tries to grab it will keep trying every 2 minutes until it becomes available. Many Thanks. DJBlu ------------------------------------------------------------------------------------ BBC2 is on the same Transponder as BBC1 England (10773H). Have you tried individually scanning that TP in Transedit? Choosing one individual video channel in, say, the Sky News interactive service doesn't work for me either. Upon scanning the TP, it shows only the video PIDS 512, 513 and 514 but using TSEdit's Analyser does show that the PIDS for each video channels (512 > 517 are being received! (see attachment). There's probably a way around it, but TBH I haven't looked into this in any depth. Llew | ||
| card, list, questions, sdvb |
