Digitalb Card in Infinity Phoenix USBDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 16-09-2007 Location: Wirral
My System: DM 500s. 95cm dish 0.1 best LNB Dark motor 1.3 |
hi all, I have just built a PC server to split my digitalb card between my front and back room. the server is running with cccam 2.09 in clarkeconnect 4.3. i tried 5 but had problems, i also had problems with newer versions of cccam. 2.09 was the latest version that worked with no problems. so all my boxes can see my server but i cant get the card working in the infinity. What is the Mhz? 3.58? | ||
| Super Moderator Join Date: 10-12-2004
![]() | That sounds like the Phoenix mode, on the programmer, for programming cards, you can switch between 3.58 Mhz and 6 Mhz. The Infinity/Phoenix USB requires 2 cables, to use phoenix mode, the USB and Serial cable, connected to the PC Com port. _http://www.infinityusb.com/default.asp?show=productsdetail&ProductID=7 | ||
My System: DM 500s. 95cm dish 0.1 best LNB Dark motor 1.3 | Got it running i just took the card out and re inserted it and now it appears. very happy!!! thanks ps running it at 3.58. | ||
| card, digitalb, infinity, phoenix, usb |
