F-type connector convertor? (noob-ish question)
Old 15-09-2009   #1
My System: Motorised dish, Echostar DSB 808 2Ci, no PC yet
I've been using an Echostar decoder for a while. It has a socket on the back marked 'LNB IN'. So does the nova-s-usb2 I'm now trying to use. And I can unplug the cable from the Echostar and plug it into the nova. But apparently it's not that simple ... Hauppage tell me (based on photo) that the nova needs an F-type connector and that my cable is something else. Based on the 2 pictures attached, can anyone tell me what sort of convertor I'd need, or if I need to strip the coax and fit some other connector (it seems there are many sorts of F-type, don't know which matches the nova in the picture), or if I'm wasting my time for some other reason?!
Thanks in advance for any info.
Kevin.
kevin-f is offline   Reply With Quote
Old 15-09-2009   #2
rolfw's Avatar
Real name: Rolf
Take the adapter of the first cable and connect the "F" type connector straight onto the USB receiver.
Rolf
Old 15-09-2009   #3
Not sure I follow - do you mean plug the cable, as shown, into the USB receiver? Because Hauppage support, having looked at just the same picture, say it's the wrong kind of connector ... Or do you mean I need to add some kind of adapter to the cable shown? If so, could you tell me exactly what?
Many thanks
Old 15-09-2009   #4
Crisbe's Avatar
Real name: Chris
My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!)
I am not sure if it is, but looking at the first picture it looks like you have an F connector fitted on the end of the coax cable and that is screwed on to an adapter which is converting it to a push on connector. Unscrew the cable connector from the adapter and you should be left with an F connector.
As you say you are a newbie, just to explain:
An F connector is a screw on connector. It does not have a central pin as such, it uses the solid centre core of the coax as the pin. So if you unscrew the end connector, off the adapter, you should find that it will give you a screw thread fitting with a short piece of the solid centre core sticking just out past the end of the thread, which should fit straight on to the connection marked LNB in.
Crisbe is offline   Reply With Quote
Old 15-09-2009   #5
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
I know I'm stating the obvious but why not leave the push-on adaptor in place and simply push the damn thing onto the Nova?
The whole point of the push-on adaptor is to make rapid transfers between boxes easy.
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 16-09-2009   #6
Crisbe - thank you so much for explaining that. Pity the guy from Hauppage isn't so helpful. Since he had said "that's not F-type, that's why it isn't working", having read your post I removed the push-on adapter, and was able to repeat the problem reproduction steps having eliminated the alleged factor.
PaulR - you're quite right, however. Removing that adapter made no difference to the problem Hauppage was blaming on it.
(Which in short is that my Echostar receives fine with it, but a scan with the nova finds no channels, having given it all the sat details etc.)
So I hope Hauppage support now come up with something else ...
Thanks again
Kevin.
Old 20-09-2009   #7
Crisbe's Avatar
Real name: Chris
Thanks again
Kevin.
You're welcome Kevin,
Please come back and tell us what the answer to the problem was, when you finally get it sorted, as every bit of info is valuable to the guys that try to help with problems.
Old 21-09-2009   #8
For info - problem remains unresolved ... Hauppage are now saying the nova must be faulty, but I'm not entirely convinced and have posted details in the 'computers' forum.
connector, convertor, ftype, noobish, question
