Skystar HD2 - Scanning Channels Help NeededDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 09-10-2009 Location: UK
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD |
Hey guys Ive now picked up this card, and got it working but im having some trouble setting it up to find channels... Ive had a look around on some forums for guides etc but nothing stands out I am using DVBviewer pro, and im sure the correct frequencies to scan the channels for my area is Eurobird 1 & Astra 2A/2B/2D at 28.2°E but using the wizard scan in DVB only brings up 10 tv channels :S I cant remember which other frequency I used before, but I remember after it scanned it found a hell of a lot more channels, Also I cant seem to find ITV HD or how to tune it in Hopefully someone can help as this is doing my head in! | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Welcme to the forum Lord Kram. For ITV HD, check post # 6 in this thread - http://www.satellites.co.uk/satellit...-skystar2.html Don't know why you've suddenly lost the ability to find other channels on 28E. Possible dish misalignment or cable problems? Why not use Transedit for scanning channels? You can download it from the DVBViewer members' site. Much more user friendly. Llew | ||
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD | I think I found out what the problem was I changed the step size in DVBviewer TE2 to 1mhz, and starting the scan and already with only 3% scanned its found over 800 channels! I cant seem to find the option in DVBviewer pro, to change the step size to 1mhz though | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Can't do that, as it uses the .ini files in the Transponder folder for scanning the channels. | ||
| | #5 | ||
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD | Ive now sorted out the channels problem, thanks for your help on that ![]() But for some reason. whenever I goto select a different channel from the list, each time I have to go to settings and select video output B to be able to get a picture? Ive played about changing the decoders etc in settings, but cant seem to stop it Any ideas? | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Can't see that option in Settings in my DVBViewer. What codec are you using? | ||
| | #7 | ||
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD | In DVB viewer pro I have tried to use all the different settings and codecs, but I still have to keep swapping between output A and B each time I change a channel Heres a few screengrabs below In no 1 and 2 theres some of the settings ive been using, bt I have noticed in no3 theres also an option under dvd option My graphics card im using is a ATI radeon 3870x2 and im using windows 7 x64 RTM Could it be something to do with the os or drivers? | ||
| | #8 | ||
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD | Also I forgot to add this capture as well of the menu: I know its not the biggest problem in the world, but its extremely annoying To me it seems like the program is having problems switching between the different channels that use different bitrates/codecs? | ||
| | #9 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Gotb to go for a 'flu jab now, I'll check it out later. | ||
| | #10 | ||
| Specialist Contributor Join Date: 29-06-2009 Location: UK
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards | ..Had my jab yesterday Llew ... I know its a 'dead' sample of virae they stick in your arm ...but I feel like crap today .. ..and if previous jabs are anything to go by ...I'll feel like crap for a week. | ||
| | #11 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I usually get a bit of a temperature for a day or so, nothing untoward. Better that than the real thing mate | ||
| | #12 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I have an earlier version of DVBViewer with my satellite setup, which doesn't have the two Video options, but I do have the later version for Terrestial. With that, I use the same codecs for both A and B, and don't have any switching problems there. Llew | |||
| | #13 | ||
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD | Ive tried using the same codecs and different codecs for video A and B but with no luck Also tried the same with the audio tab Which MPEG2 and HD/MPEG4 codec do u use? and which video renderer do you tend to use? This problem is starting to annoy me, have tried everything it seems! | ||
| | #14 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I'm using these old faithfuls without any problems on my satellite setup. I have an NVidea graphics card, and set the Renderer as shown. | ||
| | #16 | ||
My System: 3.2Ghz Quadcore PC 6GB Ram ATI 3870x2 Radeon Windows 7 x64 Ultimate Skystar HD2 card with Sky+ HD | I dont know what the problem was, but ive downloaded the latest beta version of dvbviewer from the members page, and now everything is working perfectly! Must of been a dud build ive been using | ||
| | #17 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Glad it's working OK now. Yes, using the Pro version. Might update mine to the latest too. | ||
| channels, hd2, needed, scanning, skystar |
