Setting-up USB DVB-S receiverDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 07-10-2009 Location: uk
My System: USB DVB-S |
Hi; I have bought a USB DVB-S receiver that came with BlazeDTV on the driver CD. I installed the driver and the software, but when I try to find channels in BlazeDTV it always shows the signal strength as 0% and quality between 5-10%, even with the LNB cable disconnected. It doesn't find any channels when scanning Astra 2D and won't lock to any satellite. I then tried ProgDVB; it finds my tuner OK and this shows the signal strength as 70-90% and quality between 5-10%. However, it still won't find any channels when I search. I'm hoping to be able to watch the FTA channels on Freesat, could anyone help me with this? Thanks. | ||
Welcome to the forum m1024 I think we will need a bit more background information regarding what dish setup you have and if you know it is already working using standard stb. I suspect you are just not setting the parameters up correctly for the lnb but them I am just guessing at this stage but it is a common mistake. | ||
| | #3 | |||
I'm actually staying in privately-owned University hall of residence at the moment, and there are satellite TV wall sockets in every room. I can see the dish on the side of the wall outside, and it seems to be a just a basic single dish, single LNB setup, though there seems to be a few different cables coming out of the LNB. I've tried a number of different LNB settings, but I think the right one is 9750/10600. I used the preset settings for the Astra 2D satellite in both programs. | |||
| | #4 | |||
No I do not think you are correct, is there not a universal option you can select?. You see now that we know more about what it is you have got there it could be a smatv system it could be multiple dish and you can only physically see one dish, the other being on the other side of a parapet the possiblities are endless, does the dish work with a standard stb or have you never tried it? how do you know it is connected up behind the wall plate? Also how do you know it is pointing at Astra 2? you are being very economical with information which makes it difficult to give concise answers. The way you describe the lnb, it could just be a simple octo with eight feeds from lnb going to 8 different rooms. | |||
| | #5 | |||
I am pretty sure that it is connected to something, because I once connected my DVB-T USB tuner to the Satellite socket with an adaptor and it found 51 channels; normally I get around 80 channels when connected to the aerial socket. It's a three-way wall panel with sockets for DAB, Freeview (DVB-T) and Satellite. The place was advertised as having satellite TV in the contract aswell. I honestly cannot say exactly how it is wired up between the wall socket and the dish though. I might ask the management and see if they know anything about it. Sorry I couldn't provide more info, but I only know about what I can actually see at the moment. | |||
| | #6 | ||||
See this _http://www.jneuhaus.com/fccindex/letter.html I would tend to set it for custom 10,700 - 12,750 then do a scan I take it you mean the face is pointing south and the edges are aligned East - West I would certainly contact management first since if you damage their setup in any way they will no doubt make you liable. Anyhow students should not have time for TV they should be studying shouldn't they | ||||
| | #7 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | I suspect Ku-L means Ku Band detection and L Band IF ...... which is what DVB-S equipment is looking for. So that's the setting you want. When I was at Uni, I was the only kid on the block with a Telly (Black and White .............). I also had a small Cocktail Cabinet. Thanks to Marconi (Remember them?) for paying my Bursary ............ and making me temporarily quite popular! | ||
| | #8 | |||
| | #9 | |||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | ![]() More puzzling is the apparent direction of the Dish. Also, I wonder if there is a proven connection between his room's socket and the Dish? | |||
| | #10 | ||
Having got little else to do owing to a stinking Cold, I've ![]() Here's the relevant Text: " .......then choose your LNB type. You may need to check your LNB LOF frequencies ........... 1. Choose "Ku-L Band" will set your LOF1 Frequency as 9750MHz and LOF2 Frequency as 10600MHz 2. Choose "Ku-C Band" will set your LOF1 Frequency as 10750MHz and your LOF2 Frequency as 0MHz 3. Choose "C Band" will set your LOF1 Frequency as 5150MHz an LOF2 Frequency as 0MHz 4. .......... Custom ............" Link to Manual: _http://www.matchboxpro.com/docs/Match%20Box%20Manual.pdf I'm not sure if the quoted text clarifies, or confuses! Too busy sneeeeezing | ||
| | #12 | |||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | See last few Posts: Looks like "Ku-L" is the correct setting as this makes your LNB Local Oscillator Frequencies correct for a Universal LNB. But I note you used 9750/10600 early on and it didn't work. Are you positive that your room is actually connected for Satellite? There being an appropriate socket and an appropriate Dish isn't enough: The Distribution system needs to be identified and checked ... Edit: Do you have a neighbour with a known working Sky or Freesat Box you could attach, just to prove the rest of the system? | |||
| | #13 | |||
Using a normal box would be tricky as I don't actually have a proper TV with me, just a 19" LCD Monitor with D-Sub and DVI inputs, and 2 laptops, I don't know anyone else that has tried it either. As I said, ProgDVB manages to get a 70-90% signal strength so I'm quite sure that it's connected somehow. | |||
| | #14 | ||
| | #15 | |||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Just as a matter of interest, what readings (if any) are showm if you disconnect the Satellite cable? | |||
| dvbs, receiver, settingup, usb |
