How to use SKYNET with PROGDVBDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 09-07-2003
| when u install the skynet exe, tell it to add module to prgdvb, then open up your progdvb modules folder. open the skynet.ini file and add pids [down near the bottom of the file] and also change the drive directory that u want files saved to eg disk=d:\ dir_temp=d:\inet\temp dir_ok=d:\inet you may have to create a folder inet and a folder temp within inet. It is a fantastic module, I have files up to 1.6 gig, very kind to cpu. | ||
| Regular Member Join Date: 16-06-2004
| Thanks Clarence! it work, but now I need to know how to use it. Can you provide me with a dummies guide on how to download file using SKYNET and on which satellite should I point my dish. Anybody there other than Clarence would like to help me. thank you in advance. | ||
| Well basically, the g key brings up the file types and min max file sizes. U use the arrow keys to scroll and the + & - keys on the numpad to edit file sizes , adding a plus to a file type tells skynet to grab that sort of file. pushing g again makes the edit screen disappear and ctrl+s saves your edited setting. then the arrow keys scrolls up and down the stripes and the delete key will delete a file that is highlighted. m & n keys scroll the text info at the bottom of the screen.There are a few more commands that will take too long to describe but there is an english translation of the readme floating around somewhere. Its all a bit dossy, but easy to get the hang of. I am in Australia so I have limited sats to play with. Lyngsat shows data transponders [the pink ones] and footprints for sats. Hope this helps. | ||
| | #14 | |||
| | #15 | |||
| | #16 | |||
I see the bars going up and down, but one of my friends told me that there are schedules on the internet of files (DIVX FILES) to be transmitted. Those are the files I want. Best Regards | |||
| | #17 | ||
| I think skynet is always going to be pot luck, if you leave it going 24/7 you should get some large avi files. I have experimented with a few different sats and sp's. some have heaps of traffic but low bandwidth, lots of timeouts, others have low traffic and occationally very high bandwidth users. The fastest I have seen so far is 350 kbps, but that is rare. an average good speed is 50kbps. A friend of mine got a 1.8 gb game last week. Do you have some different sats and isp's to experiment with? | ||
| | #18 | ||
| Regular Member Join Date: 21-06-2004 Location: Staffordshire
My System: Phoenix Apollo ci converted to OpenBox. Sky_star 2 PCI card. Nokia DBox2c. Sagem Dbox2c. 60cm Channel Master @ 28° ALPS LNB. 60cm Channel Master @ 19° Syntec 2000LNB. Diseq Switch. Panasonic TU-DSB30. Duolabs Dynamite & Cas2+ interface. Matri | Hi, can you point me in the right direction for skynet.exe please | ||
| | #19 | ||
| I think it is here somewhere as well http://www.dvbsoft.net | ||
| | #20 | |||
My sat is pointing at EUTELSAT W3 OPENSKY INTERNET. | |||
| | #21 | ||
| Member Join Date: 06-06-2004
| Hi Does anyone have the full instructions for skynet and ednet. It was working on my pc but nothing is downloaded anymore I think I may have pressed a wrong key I have tried uninstalling and re-installing but made no difference | ||
| | #22 | ||
| Member Join Date: 16-11-2004
| Hello Guys, i have been working with SkyNet for a weak now but i could not get much. the problem is IPE is too high. i can only get small files but no luck with larger ones. i am getting SNR of about 10.6 and the signal level is about 52%. does anyone know how could i reduce the IPE so i can get the files witout errors? i have 120 cm dish with a DiseCq and 3 LNBs. | ||
| | #23 | |||
| Regular Member Join Date: 04-09-2004
which card ur using. i hope it may be skystar2. change stream reader.dll to latest version 1.0.0.210 ( old version 1.0.0.205). I have got cc errors and IP errors with older stramreader,when I replaced with newer steam reader it is working fine. | |||
| progdvb, skynet |
Similar Threads | ||||
| diseqc 1.2 and progdvb | taynet | Satellite PC Card Receivers & Internet by Satellite | 5 | 08-03-2007 03:51 PM |
| progdvb & ss2 help | andy-gi | Satellite PC Card Receivers & Internet by Satellite | 5 | 05-07-2005 06:24 PM |
| Progdvb Question? | ripley607 | Satellite PC Card Receivers & Internet by Satellite | 1 | 02-03-2004 12:13 PM |
| Please help with progdvb and emu | raemno | Satellite PC Card Receivers & Internet by Satellite | 1 | 19-01-2004 10:48 PM |
| ProgDVB and Multidec API | darknebulae | Satellite PC Card Receivers & Internet by Satellite | 2 | 01-09-2003 11:01 AM |
