Newbie Very Confused :{Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 22-06-2004
H i have a Pinncale PCTV CI card, i brought this with the (mistaken ) view i could watch SKY using my viewing card and a CAM. I now know i cannot get a CAM to watch SKY. Is there anyway i can watch SKY with my viewing card... An idiots guide would be very helpful! | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | | ||
| What channels can i receive with a PCTV Sat CI card then? If i use a CAM will i be able watch any other TV Channels, if so which CAM would you recommend which channels will i be able to watch.... | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | I don't know exactly what card you have, but if it's a PCI satellite card, then it's likely to be able to view many TV channels. There are hundreds and hundreds of free TV channels broadcast to Europe, and many more encrypted ones. It is possible with some satellite cards and some software to be able to view many of those as well. There are several 'popular' satellites above us, although a non-motorised dish can only point to three or four at a time (maximum, if modified), a standard sky dish won't be up to much. Maybe three or four of the more powerful ones if you're lucky, and only one at a time. It's not big enough for anything else. Have a look at www.lyngsat.com to find out what's available. | ||
| | #5 | ||
| Specialist Contributor Join Date: 19-05-2004 Location: South East England
My System: Samsung A300W with component output Hotbird & Astra2 | | ||
| Every little helps and a little help goes a long way! | |||
| confused, newbie |
Similar Threads | ||||
| kaka e vegetal 100 % fcis 9080 usb | greenlion | Galaxis / Mvision | 16 | 23-11-2006 11:52 PM |
| Rumores & Boatos KAKA III | HD2All | Sat Tuga Bar | 48 | 20-08-2006 03:10 PM |
| Preciso de Ajuda | Bonitovsky | Galaxis / Mvision | 4 | 20-03-2006 11:57 PM |
| help for a very confused newbie | newbieDVB | Viaccess | 1 | 22-01-2004 11:02 PM |
| newbie newbie | pluto | Satellite PC Card Receivers & Internet by Satellite | 1 | 26-06-2003 01:49 PM |
